27.5°W Intelsat 901
  • 11610 V,4374,3/4,Dvb-S2/8PSK,ACM,Single-Packetized:
    Siminn Radiomidun: Pid-512,U:228.5.6.8
    Even if this transponder has Packetized stream and is well known by all users,this time I'll post it here to "IP over DVB>Ku",although it's placed at Data,because at 512 it has a video HEVC stream in,actually a regular TV program:Siminn TV,from Reykjavic.It's an IP service from the same Siminn Radiomidun provider,which we find at 3.0W,on 12711 V,4048,1 /3,that bobo2 talks about here
    /edit by qwer:LINKS disappeared (01.08.2020).
    I hope the moderator will agree to open a new thread with this transponder to this section of the forum :72:
  • 11689 V,500,89,S2-Q Radio
    Radio IP stream from Ireland with six tracks:
    Pid-101:Audio#1-AAC(LATM),48.0KHz
    Pid-201:Audio#2-AAC(LATM),48.0KHz
    Pid-301:Audio#3-AAC(LATM),48.0KHz
    Pid-401:Audio#4-AAC(LATM),48.0KHz
    Pid-501:Audio#5-AAC(LATM),48.0KHz
    Pid-601:Audio#6-AAC(LATM),48.0KHz.
    Who wants to listen,here with PotPlayer.
    added:corrected link.
  • 11689 V 500 . The pack is in Vertical not H as on flysat.
    Sad ,that fs racers do not have few seconds to check their own reports... :28:
    Kovosat 115cm, KaD band,
    DR HD F15,Octagon SF8008
    TBS 6983
    ...It's an IP service from the same Siminn Radiomidun provider,which we find at 3.0W,on 12711 V,4048,1 /3,that bobo2 talks about here
    here
    228.5.6.11-added another iptv stream,this for the TV package offer.
    So we have two streams ip over dvb running simultaneously.
    Loc:Romania.
  • 27.5W
    11610 V 4374
    Status for 02.02.2020 10:00 CET
    PID 512
    228.5.6.7:1234 - Radio 1 (mp3 32kbps 48000Hz)
    228.5.6.7:2345 - Radio 2 (mp3 32kbps 48000Hz)
    228.5.6.7:3456 - Radio 3 (mp3 32kbps 48000Hz)
    228.5.6.7:4567 - Radio 4 (mp3 32kbps 48000Hz)
    228.5.6.7:5678 - Radio 5 (mp3 32kbps 48000Hz)
    228.5.6.7:6789 - Radio 6 (mp3 32kbps 48000Hz)
    228.5.6.8:2345 - Sjónvarp Símans (HEVC 640x360 around 450kbps)
    228.5.6.11:1234 - Síminn Sport (HEVC 720x404 around 600kbps)
    The content of video streams is changing very often. Looks like the radio streams are stable.
    As far as I know, there are broadcasting these stations:
    - Stöð 2
    - N4
    - Sjónvarp Símans
    - Síminn Sport
    TBS 5927
    Gibertini 100cm with SG2100 - Inverto Black Ultra (Twin)
    Gibertini 150cm - Inverto Black Ultra (Single)
    North-East of Czech Republic
    Looks like the English championship promo stopped,udp://228.5.6.11,port 1234. There are two streams left,one TV,address,udp://@228.5.6.8,port 2345 and one of Radio(Music,excellent :73: ),udp://@228.5.6.7,port:3456.
  • Hi, can I have question? How can I listen/watch this tp? I have TS Reader, but I see other information then on Satesco screen. Do I have wrong version of TSReader, or do I need change setup? How? Thank you for help.
  • A method by which you can see this stream is as follows,as in the image below.
    Test done at 3.0 W from the same provider as at 27.5 W.
    Loc:Romania.
    11608 V,5723,3/4,16APSK,ACM-Packetized(new symbol rate),
    same pid & address-512 :
    U(dp):228.5.6.8:2345-Siminn IPTV,HEVC,
    U(dp):228.5.6.7:3456-Radio
  • FYI: Changed toppic name (Intelsat 907 before). :72:
    Ku-band LNB: Invacom SNF-031
  • 11591 V,250,8/9,QPSK2,
    two more radio streams from Q Radio,that spectrum has detected,although it doesn't even appear to exist as a useful signal :79:, (listen with PotPlayer). I have to admit,I'm surprised by that,all the more so with the spot is outside of my area:
