46.0°E AzerSpace-1
HK6 Télé
Thes Channel From Congo-Kinshasa
Probably not regular services and only occasional feeds...
3894 H 2900 3/4 DVB-S2 QPSK, ID: GOSPEL_TV (no data on VPid/APid unconnected)
3898 H 2083 3/4 DVB-S2 8PSK, ID: NCBN FM (NCBN TV not active)
No changes...
Active again content on!
Nigeria Customs Broadcasting Network (NCBN)
Just another scan in range 4,1 to 4,15 GHz in vertical spectrum - nothing new appeared
Another look here - no changed parameter.
Here's my today confirmation
qwer : I can't see these frequency on my home
Please Check in your Dishes..
3780 V 1000 2/3 - DIRA TV
3741 H 2500 5/6 -News Central
3885 H 1587 2/3 - HK6 Télé
3898 H 2083 3/4 - NCBN
3905 V 2900 3/4 - SUNNA+SALT
3902 H 1582 2/3 - SALT TV
3904 H 1548 Auto - Telly 4 Africa
4115 V 2423 3/4 Channel Ten
3780 V 1000 2/3 - DIRA TV3741 H 2500 5/6 -News Central
Hi khaled Star,
you can see in attached files those active frequencies (3898 H, 3902 H, 3741 H, 4112 V, 4114 V RTV) .
Not active: 3780 V, 3885 H, 3904 H, 3905 V and Channel Ten/Channel Ten Plus is on 4112 V (your own report on FlySat).
Hi khaled Star,
Thanks qwer for These Report
In circular now, signal and content check on 4160 & 4180 R 16325 3/4 DVB-S2 8PSK
Content at this time.
Just a signal check on those...
3823 V 3333 3/4 DVB-S2 QPSK, DASH minimux
3993 V 1666 5/6 DVB-S2 QPSK, PLUS TV
Scan in vertical ranges...
Signal increased a bit on 3755 V.
Hi qwer,
How about signal level at 4160/4180R? I saw your report on FS. That's really circular ploarity?
Hi chucky,
yes, these ones are in circular! Here my linear scan in range 4.15GHz to 4.20GHZ. I will change later polarity...
Okay checked content again - in circular now (incl. scan in range 4.15GHz to 4.20GHz).
Some changings:
on 4161 R:
- "Real Time" instead of "Fine Living", using same Pids
- "TV Imaan" - new
on 4181 R:
- "Dizzim TV" - new
2m: 4160/4180R- max: 0,4/0,1db
Complete linear scan.
Changing SR; 3961 V 2329 3/4 DVB-S2 8PSK, Silverbird TV package
4130 V 2000 3/4, TV E from Tanzania off at this time.
/edit: locked 4130 V now ...
Cam 10 from Cameroon on:
3755 V 1666 3/5 DVB-S2 QPSK
(...had to move my dish ~0.5° more to the east... )
...FEC 3/4 now
