Laminas2,4m Antennenkonstruktion.
Das Gegengewicht kommt noch zu bauen.
Bauen.DX Bozóth,Pongisat,Feci01.
Feci01 Laminas 240x270.
Original von feci01
I am delighted not so much with the excellent antenna as with the skill, ingenuity and engineering calculation when installing the antenna.
Bravo-bravishimo!However, I consider it my duty to inform you that the LNB axis, which is aimed exactly at the center of the mirror, is a sure sign of incorrect alignment of the antenna feed.
If you are interested in this issue, you can discuss it in private messages.Regards, Yuri Filatov
Im März werde ich eine Parabel mit einem Durchmesser von 3,6 Metern kaufen und installieren
Antenne. -
ECHOSTAR 3,7 m.
Great feci01, go ahead!
Wir haben es gestern gebaut.
DX Bozóth,Pongikus,Feci01. -
Wie viel kann es für das dankbare Parabel-Ku-Band verwendet werden?
3,7M= 2,5M?,3,0M? -
EchoStar Die Netzwerkantenne im ku-Band ist sehr schwach.
Eine 3-Meter-Satellitenschüssel auf dem Ku-Band wartet auf Renovierung.
Hol lehet olcsón biztonságosan megrendelni a TBS profi kártyát.
Vagy ha valaki használt, jó állapotú TBS profi kártyát adna el, akkor megvenném.
Very good that you are thinking of getting a pc card.Of course it is easy for me to give suggestions,because I do not give the money,but I repeat what I said another time,at your large antennas it is worth buying a professional card that has full support,as are those highlighted by me in the pic.
In fact,as it shows us most of those who post here use such cards,especially those,like you, have large antennas.In fact,as it shows us most of those who post here use such pc cards and,like you,have big antenna.If you wouldn't have antennas like that,maybe I wouldn't insist so much.And I don't think I'm wrong if I say that a professional card highlights the performance of your antennas.
I wish you inspiration and good luck
Best regards.
