New sat is on. What a signal .
62.0°E Intelsat 39
Yes, great marval450! I can lock most as well.
Unfortunately, this morning my PC didn't boot and I ended up removing both the video- and TBS-6925 card. Now the scans show these ugly peaks. I remember others report this too, but don't know what they did to solve it.
Edit: solved, I accidentally reconnected the coax to LNB-out instead of LNB-in
Iranian feeds active now on 10972 V 3800 (HD football) and 10979 V 1300 -
Danke marval450.
Scan Omiciom S2. -
Unfortunately,my area is not very favoured by the new spot.I am at the edge of the spot,therefore only from time to time when I lock a signal on verticall pol,so far only the IRIB package,with fluctuating signal,between 4 - > 8dB.
10988V 10.2db currently (2.4m + SF8008)
Only 11555V there is no lock, not sure why -
Test on 115cm dish.
From time to time the signal increases,but eventually returns to the same level as before.
New fr.
11193 V 1600 3/4 DVB-S2/8PSK Al Wefaq TV HD
Typo on FS?
62°E
11576,V,1599,34,8PSK-New frequency for Al wefaq HD tv -
Original von milan58
62°E
11576,V,1599,34,8PSK-New frequency for Al wefaq HD tvAgain,
11074 V 1600 1/2 QPSK2 Al wefaq
I locked two IRIB transponders atm
11001 V,3500,3/4,8PSK-IRIB,
11554 V,30000,3/4,8PSK-IRIB package -
New (FS)
10969 V 16500 3/4 DVB/S2 8PSK - NO LOCKED -
10969 V 16500 3/4 DVB-S2/8PSK.
IRIB UHD test.
2,4m Laminas.6,5 decibel no lock.
DX Bozóth.
3m Andrew.8,0 decibel lock. -
Yesterday i tried to lock it but with 50% success only. 7,6dB-7,9dB was maximum. Signal was unstable and it was hard to see something. too big BER too low signal.
i can only confirm that there is "irib uhd" with yellow logo.
tomorrow will be next try. Now I cant check it :( -
Hi Tomek22 ,I can confirm the transponder-10969 V,but not the tv program for obvious reasons
10969 V has 6.5 dB here, so still 1.5 dB lacking.
Getting two "no locked" on 11650 V and 11662 V, suspect a different beam, anyone can lock?
hvdh - 11663 V is listed on fs as data , so the other will be probably data too.
Original von marval450
hvdh - 11663 V is listed on fs as data , so the other will be probably data too.Hi,
yes signal is jumping up and down on 11650 V and 11662 V, so I would say it´s probably GS.
Just my scan/signal at this time - also for 10969 V 16500 3/4 DVB-S2 8PSK.
Yes, I overlooked on Flysat because that frequency is not sorted properly!Added last night's scan of 10.95...11.2 GHz to my previous post.
6.5 dB on 10969 V is "too much" for my small dish, either I'm at a lucky location, and/or nighttime is the best time to chase a lock. -
I can lock 10969 V at this time on the limit - getting one screenshot (on recorded TS).
