62.0°E Intelsat 39
  • Thanks to satdxer on DXtv today for his findings:
    3870 L 1085 3/4 DVB-S and
    3872 L 2150 5/6 DVB-S
    Just my current circular left scan. Nothing in spectrum a few days ago...
    Also new here:
    3978 L 28745 3/4 DVB-S2 8PSK, encr. package, radios fta.
    PS: Other lockable frequencies in other toppcs.
    /edit: No changes in circular right spectrum (according last scan in Data>C toppic 20.10.19.
    FYI: Started a new toppic - in hope it´s from I39.
  • Thanks qwer!
    3870l & 3872L radio packages good reception here with 175cm. Others no lock. I wil try 2.4m on this weekend.
    Original von marval450
    3978 L 28745 3/4 DVB-S2 8PSK locked .
    Btw. wrong info on fs, it is not SABC pack.
    Hi marval!
    I think that is SABC, because S1Nat, S2Nat, etc is the SABC 1-2-3+ there is the etv as well.
  • You are right chucky , I checked again,
    provider in TS is Sentech.
    SENTECH began as a technical division of the South African Broadcasting Corporation (“SABC”) responsible for signal distribution services of the Corporation. In 1992, the SABC corporatised the division as SENTECH, a wholly owned subsidiary of the Corporation.
    Kathrein 220cm , KU+C,
    Edited once, last by marval450 (November 3, 2019 at 7:49 PM).
  • New Freq., I don't know if Feed, OATV - Encrypted
    3882 L 1552 3/5 DVB-S2 8PSK
    3878 L looks like empty to me right now !
    Edited once, last by superdish66 (December 29, 2019 at 3:08 PM).
    Original von superdish66
    Now, the only one TV Stations (Mini Muxx) in R - TVM Moçambique 1, 2
    3714 R 5630 3/4 DVB-S2 8PSK
    Hope I'm right !!
    Now 3882 is off. It was a Feed. Thank you for moving to Feeds Section :72:
    3714 R no signal
    3710 R lock for me. Maybe frequency changed?!
  • OATV - Encrypted
    Not realy strong signal here.
    Complete scan - no changes.
  • 3882 L 1552 3/5 DVB-S2 8PSK
    One Africa TV from Namibia, I think it was always there during this year... but still very weak at my place. :90:
  • One Africa TV from Namibia,
    And I think It's channel Also broadcast inIntelsat906 At 64.2 E..
    To 103.0°E
    Very low signal - but it´s still on (via manual scan).
    Lockable via manual scan - complete scan here.
  • Current update both circular from my place
    Nothing to report
