• TVM mux changed parameter, not new - already reported by khaled Star on FlySat 11.07.2023 :72:
    3714 R 6666 3/4 DVB-S
    3714 R has left.
  • qwer I don't see at your spectrum Kenyan mux on 3878L. They gone? Can you try to lock they manually?
    Hi N_Stanislav,
    ah, you´re right, 3878 L didn´t appeared in my last BS above - sorry, it is still active on same parameter, but I see, that this signal is weak for me and about 0.5dB under LM... :90:
    I stay for while at this position...let´s see later perhaps.
    PS: superdish66 locked 3878 L in his last end-of-august scan :3:
  • Observing 3878 L Kenyan mux:
    Signal increased a bit yesterday evening, but it was not possible to lock it.
    Today morning, signal is more weak and about 0.7 to 1.2dB under LM.
  • 3878 L didn´t appeared in my last BS above - sorry, it is still active on same parameter, but I see, that this signal is weak for me and about 0.5dB under LM... :90:
    Changed my Kaonsat LNB and using my old Panorama 13K LNB (LOF 5145 :26. ) for this test...
    No problem to lock:
    3878 L 5572 5/6 DVB-S2 8PSK
    ...but only APId 4096 connected at scan time
    PS: Ignore polarisation, it´s in circular left. :72:
  • Oh thanks N_Stanislav :76:
    ...now I can remember that one, click! :26.
    (I will try next time)
  • Something new, but unlockable (2.0dB under LM) appeared - probably data or GS...?
    4058 R 2105 5/6 DVB-S2 8PSK
  • Reaching position 62.0°E now... :128: ... nothing new lockable.
  • New scan Parsat 3m.
    Helyszín: Nádudvar, magyar.
    2.4.x2.7.m Laminas.
    2,2 méteres fókusz.
    C, Ku sáv 95.0Kelet-55.5West.
  • This time, I used Mediastar 5G LNB(3.7 to 4.2GHz), but, as you can see on the spectrum, it doesn't solve the interference at 3700 MHz.
    What can you ask for a small antenna on the C-band arc!?
