I think from this position and not from 16.0°E or 19.2°E.
To be confirmed.
11748 H 27500 3/4 DVB-S2 8PSK
11788 H ?
~+9dB needed to lock...
To be confirmed.
11788 H ?
This TP can be from 13E ,I know it is far, but it can be weak reception by side lobe of antenna .
With hard lock I can see only -10db, sometime flicking -2,5.
Thank you marval450 - and you are right!
Tried 11785H 29900 in manual scan - and this is 13.0°E...
SORRY guys!
I let this toppic open, probably the real Amos-17 signals will have better dB values later...
PS: Never thought about 13.0°E...
is there any new reception for examble tp 11718 V without dreamsat?
No kind of signal from my place with 2,2m... yesterdays try on 11718 V.
es gibt Hinweise, dass morgens der Empfang (wenn überhaupt) besser sein soll.
a little better chance trying it in the morning.
11718 V here 2.5dB
apparently all are religious channels .
11716,5 V 30000 1/2 QPSK2 "view media" test card ...Dreamsat yesteday @ FS.
12295,3 V 30000 1/2 QPSK2
12641,2 V 30000 1/2 QPSK2
added...
According to : https://www.amos17.africa/EN/ku-band.html
there are also Ku:13.4 to 13.65 GHz
I checked in a few weeks ago and saw nothing. I'll put the LNB back on soon and re-check. The beams are supposed to be able to cover N Europe. Can you check this range, flie?
I was using a slightly modified SMW 11.3GHz LO, 12.25-12.75, PLL LNB. The NF is not too good at about 2.5-3dB over the 13GHz band.
<edit> 10/1/20 Tried 13GHz band again, still nothing.
Unfortunately I can't !
and I don't Know if using one of these Ku-extanded-lnbs can help
I don't like heavy lnbs "smw,norsat...stc" because they are (heavy,expansive, need expert !,need spetial and expensive feed-horn hard to instal ....etc
I don't like heavy lnbs "smw,norsat...stc" because they are (heavy,expansive, need expert !, hard to instal ....etc
The last 3 LNBs look very interesting. The 3rd may be the one to try. Where are they for sale?
it is on alibaba !!
https://www.alibaba.com/produc…eiletai6.5.2e776308zoZD22
and very strange too !!! you will find both lnb 12.78-13.28 & 12.78-13.98 ghz
in the same page !
may be all these 04 lnbs are the same ! but LOF changed in factory?! :
KU Band Special LNB with 11.3ghz 9 GHz 8.8GHz 11.83ghz 12.8ghz
only 02 channels this time on 12641V:
Surebet NumGames
Surebet247
11881,V,30000 QPSK2 2/3 :
Program 40721 GR B74 E31A
Program 40722 GR B56 E31B
Program 40723 GR SpanishLeagueTV
Program 40724 GR EuroChampionsTV
Program 40725 GR E39A B71
Program 40768 Surebet NumGames
Program 40769 Surebet247
My first lock on 17E with 3m PF
Hi Lambda,
thank you for your report.
You can check, if 12540 V 19970 is probably from position 16.0°E?
Happy easter to you and your family!
I'm very disappointed, these frequencies are 16E reflections :85:
using 1.21m/Televes Lnb : only +1.2 dB !
at least I can see some thing
channels in 11753V not Encrypted yet ...conax
this one I think It has some Encrypted channels :
12369,V,12133,12,2 ;3 (-1.03) dB; 20:09 15/4/2020
signal very low and dispirited later feed report reported here.
locked later with 1.3dB !!
