This came to me via a long route, from someone in Sub-Saharan Africa. I do not know the full details, apart from the dish being 1.2m and the LNB not having a precisely known LO frequency. 10.95 - 11.20 GHz and 11.70 - 12.75 GHz were scanned to find these 2 TPs. The SNR from both 11796V and 11833V was around 10dB but there was no DVB decodable on 11833.
17.0°E Amos-17
Incredibly! I am 1000km closer to the African beam and I don't have any signal from 3 meters
Original von Lambda
Incredibly! I am 1000km closer to the African beam and I don't have any signal from 3 metersI am just passing it on, it was not from my place but from someone within the Ku-2 service area.
I apologize, I hastily came to the conclusion that the signal is over your 1.2m antenna
Hi S-band
which country this person (Mali or Niger )? should be not far from me !
it is very nice to me to see some one from Sub-Saharan Africa has a TBS card -
Original von flie
PN sentHere is another scan, probably just a carrier, maybe something being tested. I don't think it is a beacon as it looks too strong.
(Scan not from my location)
thank you very much S-Band for reply
I think he has his own reasons
no sign of 10996 V here ! should be test Carrier I can't see it now
sadly I use now a small dish 0.90m with IBU !
some Transponders appear and disappear because signal is very low here :85:11016 H -No-locked- is from 16°E south-beam !
Can he show us a scan in Ku-high (11700-12750 mhz)?
Original von flie
Can he show us a scan in Ku-high (11700-12750 mhz)?Here they are but, unfortunately, these may be the last that I will get. It looks like the skew is not set correctly.
1=11717,V,30000,12,2 ;3.4 (2.4) dB; 8:39 9/3/2021
2=11752,V,28190,45,2 ;3.3 (-1.38) dB; 8:39 9/3/2021
3=11881,V,30000,23,2 ;3.5 (0.4) dB; 8:39 9/3/2021
4=12215,V,30000,34,2 ;3.6 (-0.43) dB; 8:39 9/3/2021
5=12251,V,30000,34,2 ;2.2 (-1.83) dB; 8:39 9/3/2021
6=12296,V,30000,23,2 ;2.2 (-0.9) dB; 8:39 9/3/2021
7=12332,V,30000,34,2 ;3.7 (-0.33) dB; 8:39 9/3/2021
8=12540,V,13665,34,4 ;-0.1 (-13.13) dB; 8:39 9/3/2021
9=12551,V,4550,34,2 ;0.5 (-3.53) dB; 8:39 9/3/2021
10=12718,V,5319,56,2 ;-1.3 (-6.78) dB; 8:39 9/3/2021
something has changed here :
1=11717,V,30000,12,2 ;4.1 (3.1) dB; 0:58 24/5/2021
2=11752,V,28190,45,2 ;3.9 (-0.78) dB; 0:58 24/5/2021 No locked
3=11881,V,30000,23,2 ;4.7 (1.6) dB; 0:58 24/5/2021
4=12048,H,30000,35,2 ;4.3 (2.07) dB; 0:58 24/5/2021
5=12085,H,30000,23,2 ;4.2 (1.1) dB; 0:58 24/5/2021 DATA GS (continuous-single)
6=12215,V,30000,12,2 ;3.6 (2.6) dB; 0:58 24/5/2021
7=12251,V,30000,34,2 ;3.9 (-0.13) dB; 0:58 24/5/2021
8=12296,V,30000,23,2 ;4.1 (1) dB; 0:58 24/5/2021 low signal very high BER !
9=12332,V,30000,34,2 ;2.9 (-1.13) dB; 0:58 24/5/2021 No locked
10=12504,V,4217,34,4 ;0.6 (-12.43) dB; 0:58 24/5/2021 No locked
11=12526,V,3322,89,3 ;-0.1 (-13.29) dB; 0:58 24/5/2021 No locked
12=12540,V,13665,34,4 ;0.7 (-12.33) dB; 0:58 24/5/2021 No locked
13=12551,V,4550,34,2 ;1.2 (-2.83) dB; 0:58 24/5/2021 No locked
14=12561,H,30000,23,2 ;-1.4 (-8.02) dB; 0:58 24/5/2021 No locked is from 16°E south-Beam
OK , Best signal ! today :
[SATTYPE]
1=0170
2=1.80m-Test/IBU
[DVB]
0=17
1=11717,V,30000,34,2 ;8 (3.97) dB; 21:37 2/11/2021 .............TS
2=11752,V,28190,45,2 ;8.3 (3.62) dB; 21:37 2/11/2021...........TS
3=11881,V,30000,23,2 ;9.6 (6.5) dB; 21:37 2/11/2021.............TS
4=12118,V,9519,23,2 ;8.6 (5.2) dB; 21:37 2/11/2021...............DATA GS
5=12186,V,4080,34,4 ;3.9 (-9.13) dB; 21:37 2/11/2021............DATA GS
6=12215,V,30000,12,2 ;8.6 (7.6) dB; 21:37 2/11/2021.............TS
7=12251,V,30000,34,2 ;8.9 (4.87) dB; 21:37 2/11/2021...........TS
8=12296,V,30000,23,2 ;8.4 (5.3) dB; 21:37 2/11/2021.............TS
9=12332,V,30000,34,2 ;7.9 (3.87) dB; 21:37 2/11/2021...........TS
10=12503,V,4217,34,4 ;5.8 (-7.23) dB; 21:37 2/11/2021..........No locked (Probably DATA GS)
11=12518,V,1362,34,3 ;6.2 (-4.31) dB; 21:37 2/11/2021..........DATA GS
12=12525,V,3322,34,4 ;6.7 (-6.33) dB; 21:37 2/11/2021..........DATA GS
13=12540,V,13665,34,4 ;6 (-7.03) dB; 21:37 2/11/2021...........DATA GS
14=12551,V,4550,34,2 ;4.9 (0.87) dB; 21:37 2/11/2021...........TS
15=12699,V,4951,12,2 ;2.5 (1.2) dB; 21:37 2/11/2021..............DATA GS
16=12705,V,5834,12,2 ;1.2 (0.2) dB; 21:37 2/11/2021..............TS
17=12718,V,5319,34,3 ;4.6 (-5.91) dB; 21:37 2/11/2021..........No locked (Probably DATA GS)
[SATTYPE]
1=0170
2=1.80m-Test/IBU
[DVB]
0=17
just to see some of the content of these transponders :
no thing in DVB-S2X with TBS5521
just checking this position again :
[SATTYPE]
1=0170
2=1.80mOS/IBU
[DVB]
0=23
1=11609,V,28970,78,1 ;-10 (-17.24) dB; 23:01 1/10/2022.............TS No locked (From 16°E south-beam I think )
2=11717,V,30000,34,2 ;7.7 (3.67) dB; 23:01 1/10/2022.................TS
3=11752,V,28190,45,2 ;7.2 (2.52) dB; 23:01 1/10/2022.................TS
4=11881,V,30000,23,2 ;7.7 (4.6) dB; 23:01 1/10/2022...................TS
5=11918,V,30000,34,2 ;8.5 (4.47) dB; 23:01 1/10/2022.................TS
6=12048,V,30000,23,2 ;7.8 (4.7) dB; 23:01 1/10/2022..................TS
7=12084,V,30000,23,2 ;7.9 (4.8) dB; 23:01 1/10/2022..................TS
8=12118,V,9099,23,2 ;7.4 (4) dB; 23:01 1/10/2022.......................DATA GS (can't locked manually with TBS5927 !)
9=12152,V,2429,89,3 ;0.7 (-12.49) dB; 23:01 1/10/2022...............DATA GS(can't locked manually with TBS5927 !)
10=12171,V,1165,56,2 ;0.7 (-4.78) dB; 23:01 1/10/2022...............DATA GS(MIS{ِ0})
11=12179,V,5624,34,4 ;4.6 (-8.43) dB; 23:01 1/10/2022...............DATA GS(MIS{ِ0})
12=12215,V,30000,12,2 ;7.5 (6.5) dB; 23:01 1/10/2022................TS
13=12251,V,30000,34,2 ;7.8 (3.77) dB; 23:01 1/10/2022..............TS
14=12296,V,30000,23,2 ;7.9 (4.8) dB; 23:01 1/10/2022................TS
15=12332,V,30000,34,2 ;7.6 (3.57) dB; 23:01 1/10/2022..............TS
16=12504,V,4217,34,4 ;5.4 (-7.63) dB; 23:01 1/10/2022...............No locked (Probably DATA GS)
17=12526,V,3322,34,4 ;5.4 (-7.63) dB; 23:01 1/10/2022...............No locked (Probably DATA GS)
18=12540,V,13665,34,4 ;2.8 (-10.23) dB; 23:01 1/10/2022...........No locked (Probably DATA GS)
19=12671,V,9449,35,2 ;1.7 (-4.1) dB; 23:01 1/10/2022.................No locked (Probably DATA GS)
20=12681,V,7999,34,2 ;4.7 (-3.51) dB; 23:01 1/10/2022...............DATA GS(MIS{ِ0})
21=12705,V,5834,12,2 ;1.2 (0.2) dB; 23:01 1/10/2022..................DATA GS(can't locked manually with TBS5927 !)
22=12718,V,5319,34,3 ;3.8 (-6.71) dB; 23:01 1/10/2022...............No locked (Probably DATA GS)
23=12732,V,15000,56,2 ;-0.8 (-10.15) dB; 23:01 1/10/2022..........No locked (Probably DATA GS)
it is TS Locked with 1.3dB !
12571,V,2299,34,2 ;3.9 (-0.13) dB; 22:13 7/10/2022................No locked (Probably TS don't have signal now !)
locked at the limit ! maybe it is a feed ?!
1.3dB (gray number in the upper left corner) is the SNR that the blindscan detected.
Below, and also in the upper right corner, the lilac numbers are the SNR, which IQmonitor Pro was determined by the analysis of the constellation - 5.4dB
Zitat3.8dB (gray number in the upper left corner) is the SNR that the blindscan detected.
Below, and also in the upper right corner, the lilac numbers are the SNR, which IQmonitor Pro was determined by the analysis of the constellation - 6.2dB
IQmonitor Pro detects signals better than CrazyScan
