Q-band (40.5 – 41.0 GHz)
  • It is not that long ago, when a new Ka band section for the frequency range 31.8-32.3 GHz was updated on our web sites. Right, there hasn`t been any information uploaded yet, but time to do this will come sooner or later and people such as s-band, feedsat, Peon, maybe me or somebody else will write the history once again. I`m definitely sure about it.
    I and Peon talk a lot and very often about new trends and technology in satellite business even it`s our hobby only. That`s not `cause we don`t wanna stay behind, but also we can learn a thing or two that will help us to improve the parts/reception we have now or we dream to reach at some point in the future.
    Progress can not be stopped, so right now I would like to introduce you to the different chunk of satellite band. The new and unknown frequency range of Q-band (40.5 – 41.0 GHz), because with the arrival of 5G and preparation for 6G, the satellite industry will move from Ku and Ka band towards Q-band over the next decade.
    Well, this band is not that new to satellite reception, but the first professional LNB was introduced only in May 2019 by Norsat, model Norsat Q1000H. First shipments of the new LNB was scheduled for end of Q3 2019.
    People say, if there`s a problem there`s a solution, so when Norsat started producing pro grade Q band LNBs, there must be some satellites capable of transmitting in this band out there, too.
    Yes guys, they are out there and they have been in the space for some time.
    Eutelsat 65 West A @ 65W launched in 03/2016 or Alphasat (aka Inmarsat-4A F4) @ 25E launched in 07/2013 satellites are only a few of those to carry the Q/V band payload.
    Here is a brief information about Norsat Q1000H:
    Frequency Band - 40.5 - 41.0 (GHz)
    L.O. Frequency: 39.55 (GHz)
    L.O. Stability: ± 50 KHz
    Noise Figure: 3 dB
    Waveguide: WR22 (Ku - WR75, Ka - WR42, C - WR229, X - WR-112)
    Current: 1000 mA max (WOW!!!) :43:
    Weight: 700 g
  • Thanks, sato, that's very interesting. I'd expect something much wider than 500MHz. From their web site it looks more like a feasibility study as they don't mention a specific application. http://www.norsat.com/q-band-lnb/
    Alphasat is on 39.402GHz and has been received by a few people. It is reasonably strong. https://uhf-satcom.com/blog/39-4ghz-converter-for-alphasat
    There are a few people who can get the 32GHz DSN stuff but my system is not good enough to get the craft out there at the moment. Maybe when Hayabusa 2 get closer to home, I'll hear something.
    I found this https://thalesgroup.com/sites/…t/rfpasiva-ed15_eng_2.pdf
    Which has a picture of the Q band filters from Blagovest (14L?). Has anyone seen frequency allocations for that?
    Ku wide band: corrugated conical feed, 1.5dB NF LNA, Ku (Standard): Octagon OSLO mod for C120 & ext ref Prodelin feed.
    Edited 2 times, last by s-band ().
  • I`m looking forward to reading your reports about 32GHz DNS band when time allows you to do so.
    As far as I know Hayabusa 2 is heading home and they are expecting its arrival in December 2020.
    Anyway, the following link is a bit off topic, but it may help some of us to find out a few more positions when a beacon/telemetry peak is found on the spectrum. Or, some of us can improve the site by sending their own findings.
    http://frequencyplansatellites…pe-Africa-MiddleEast.html
  • Here are some pictures of the set-up used for Alphasat on 39.402GHz.
    It is part of an old experimental link RX head end, thanks to uhf-satcom. An external, 9.5GHz, GPSDO locked source is multiplied, in the harmonic mixer, to give a 38GHz LO. The noise figure is in the region of 8-10dB with a linear polarised feed on a 220mm Cassegrain dish. It had been stored in a dusty environment for a while and the LNA chip shows it. There have been problems with poor connections but repairs are difficult.
