10822 H 30000 3/4 QPSK ? which mux and beam
seems to have 10865 H with same SR (bad weather conditions today)
PS: not a crazy scan error, tested 3 times
confirmed, it was a scan error.
tested today with the exactly same configuration (lnb, antenna, PC card, cable ,etc), nothing found in low band.
I can't explain what happened last time. ?(
Hvdh ?
Intelsat 20 - 68.5E
11489MHz - Vertical - SR: 1239,377 Ks - 3/4 - DVB-S2 8PSK Pilot : OFF -Coding Mode : CCM Bitrate : 2,762 Mbit/s
Anscheinend eine Neue Frequenz mit einem Program , ob es einen Feed oder einen dauerhaft program ?
Abotabad Centre
Das sind feeds aus Pakistan (Kay2 TV?), vorher manchmal zu finden umgebung 11540 V (mehrere träger), und immer mit SR von 1239.
Satellite scanned today:
ITs new Frequency 12522 - 30000- H
Great find, this transponder is active again!
12522 H 30000 2/3 DVB-S
Siyaya TV seems to be a South African pay-tv provider...
12641,H,1406,12,QPSK- ACBN
New modulation and s.r.
12641,H,1582,12,DVBS2/QPSK-ACBN
Changed parameters: 12522 H 27500 3/4 DVB-S
RTM, 4WG TV, TTMV TV, CFTV
Scan of the day with EBS and CS
10972 H 15000 3/4 8PSK
New pack of Tajikistan channels,FTA.
Today scan
12638 H, 3786, DVB-S2 QPSK,3/5
PMT PID 32 (0x0020) - Program 1 Retro TV
PMT PID 36 (0x0024) - Program 257 ACBN
PMT PID 40 (0x0028) - Program 513 Digital 1
[SIZE=1]/merged by qwer in this toppic.[/SIZE]
Welcome to the forum feci01 (and first post)!
A new QPSK signal below lock, why is it so weak?
10975 H 3330 (approx.)
12634 V is off,
new mux?
12641 V 5000 5/6 QPSK2
No picture on programs.
68,5°E Africa beam
12637,H,3786,35,DVB-S2/QPSK He,he signal varies from 1-2.5dB
Thank you for your contribution, milan58!
Scan from my place (2.2m).
Something big is at 10990 H , SR found different, around 60000
Hi Feedsat_DX,
Please, when you visit 68.5E position,check freq 10990 H if it is in NS3/NS4? It seems to be of this type
Thanks
