New scan,data.
11052 V 8332 3/4 DVB-S2/32APSK.
11078 V 5399 3/4 DVB-S2/32APSK.
11119 H 2761 9/10 DVB-S2/16APSK.
11119 V 3250 7/9 DVB-S2/16APSK.
11122 H 2761 9/10 DVB-S2/16APSK.
11132 H 5523 9/10 DVB-S2/16APSK.
11137 V 3250 7/9 DVB-S2/16APSK.
11181 V 13999 3/4 DVB-S2/32APSK.MULTISTREAM:1,2,5,16,50.
11485 H 1161 2/5 DVB-S2/QPSK.
11479 V 3497 4/5 DVB-S2/32APSK.
11489 H 1297 3/4 DVB-S2/32APSK.
11501 H 2999 1/2 DVB-S2/QPSK.
11578 V 3839 3/4 DVB-S2/32APSK.
11587 V 5200 3/4 DVB-S2/32APSK.
11588 H 11999 1/2 DVB-S2/QPSK.
11608 H 2999 8/9 DVB-S2/16APSK.
11678 V 2603 7/9 DVB-S2/32APSK.
62.0°E Intelsat 39
11074 H,2763,1/4,S2,ACM-Data(new).
I can't lock the signal with any card that covers 10700-10950 MHz Maybe someone else has a more suitable device and,why not,good luck -
Your scan vaguely shows three 72 MHz transponders (10745, 10825, 10905) according the frequency plan. Probably Steerable 2 beam (to unknown direction), since there is nothing to see here in the scan. -
Hi,
I can confirm these TPs, a few days ago now. Can´t check at this time, because skew probs atm. ...
Hi,I can confirm these TPs, a few days ago now. Can´t check at this time, because skew probs atm. ...
Okay, I´ve changed servo for Ku-skew now.
Nothing can be seen from these TP in low Ku-band at this time.
11598 H,2500,3/4,8PSK,CCM-new Data(AOL),
Új beolvasási omicom.
Adat.
10744 V 31997 1/3 DVB-S2 / QPSK.DATA.
10968 H 5119 4/5 DVB-S2/16APSK.DATA.
10979 H 3124 4/5 DVB-S2/16APSK.DATA.
11050 V 3332 3/4 DVB-S2 / 32APSK. ADATOK.
11076 H 2761 2/3 DVB-S2 / 16APSK, MULTISTREAM 0, ADATOK.
11079 V 5399 8/9 DVB-S2 / 16APSK, MULTISTREAM 0,1,2,4, ADATOK.
Unname 1,2,3 MULTISTREAM1.
11083 H 5521 8/9 DVB-S2 / 32APSK, MULTISTREAM 0, ADATOK.
11598 H 2499 DVB-S2 DATA.AOL1,AOL2.
11651 H 3249 5/6 DVB-S2 / QPSK, MULTISTREAM 0, ADATOK.
11643 H,47620,1/4,S2,ACM-PacketizedMaybe a user will be lucky enough to lock the S2X extension.
Reception of 11645 H - data
New - 11600 Hor
11648 H,39000,1/2,S2-Packetized,new symbol rate,
11143 H,47619, 1/2,S2-Packetized,new
Locked with tbs6590
Der Transponder 11078 V 5400 ist sogar mit 4 Streams ( also MIS )
1 ; 2 ; 4 ; 48
Thanks for the table and for the info. I thought about this spot because of which the signal is weak, although it is strong on this polarity. Unfortunately, I have problems with the signal due to terrestrial interference. Because of this, the signal is unstable no matter how strong it is, varying by as much as 6 dB. You can compare the signal in the previous picture and the one in the current one. It is a big difference, which says everything about the difficulties I have to have a normal reception, even with a small antenna in this position.
62.0E is a curse for my antenna and location due to several physical factors that negatively influence any reception.
With great difficulty, I managed to lock 11504 vertically.
Now try this mux in your area. Thanks again
Regards
