31.5°W Intelsat 904 (incl.) (ex 27.5°W 29.5°W)
  • Just another spectrum in December 2024 scan... nothing lockable... inclination at scan time 5.39° north (a bit over my elevation limit)
  • Just my first scan in year 2025... inclination at scan time was 2.28° south...
  • Just another look here after two month... inclination at scan time was 3.10° north...
  • qwer November 9, 2025 at 10:32 AM
    Changed the title of the thread from “29.5°W Intelsat 904 (incl.)” to “31.5°W Intelsat 904 (incl.) (relocated from 27.5°W/29.5°W)”.
  • ...just on the way too find this satellite... but I cannot verify, if this one is Intelsat 904 (incl. at scan time 0.76° north and moving rapidly south) or if it is Intelsat 25 (incl. at scan time 0.59° north and also moving south)...
    Big peak on 4192 on both circular poalarties... probably this one is linear... I cannot remember about this one.
    /edi1t: Not sure, but probably it´s from Intelsat 25 (?) - incl. now 0.48°N - because I only had to move few steps elevation more south.
    Intelsat 904 - incl. now 0.14°N - much more south than before...
    /edit2: Now Intelsat 904 is under 0° (I 25 at 0.40°N) and peak on 4192 is nearly lost, even when I try to find via elevation setup...strange :28:
  • 4192 MHz must be from a normal transponder, not TT&C.
    If linear (vertical), it's IS-25. If circular, it's IS-904.
  • Big peak on 4192 on both circular poalarties... probably this one is linear... I cannot remember about this one.
    Thank you hvdh :73:
    I´m still in circular-mode and checked situation again while both satellites are more than 1° in different inclination elevation.
    4192 is too weak at this time and probably only "visible" on Intelsat 25 - on both polarities - so it looks like linear vertical but I had to check it again when I´m back on linear setup next...
  • Just another try here... this time in linear - but nothing can be found at 4192
  • Just another look on circular spectrum... inclination at scan time 0.40° south for Intelsat 904 (and 0.30° north for Intelsat 25)
    4198 "visible" on both polarities
  • Arrgh... I ´m in linear scan now...
    Trying to find Intelsat 25 (inclination at scan time 0.70° south)... but it looks like I found Intelsat 904 - inclination at scan time 0.46° south...
    Two locks possible...unknown polarisation...
    4096 (L/R?) 17728 (I think also in S2X)
    4122 (L/R?) 4975
  • Two locks possible...unknown polarisation...
    4122 (L/R?) 4975
    I´m back in circular range... inclination at scan time 0.08° south
    now it´s clear:
    4096 R 17728 (TS in S2) - confirming GSE in S2X
    4122 R 4975
  • qwer May 3, 2026 at 8:54 AM
    Changed the title of the thread from “31.5°W Intelsat 904 (incl.) (relocated from 27.5°W/29.5°W)” to “31.5°W Intelsat 904 (incl.) (ex 27.5°W 29.5°W)”.
  • Just another circular scan here... inclination at scan time 2.93°south...
    4096 R has left
    4109 R 4545 is new in S2X (GS)
  • No big changes hewre in circular scan... inclination at scan time 2.00°south...
    4109 R 4545 is still in S2X (GS)
    4123 R 5000 is still on - changed SR
