03.1°E Eutelsat 3B
    11660 V 30000 3/4 16APSK weak, Steerable or East beam ?
    Can you check this ?
    Hi Feedsat,
    I hope, I don´t forget this and will check it later.
    Best Regards
    qwer.
  • Hi Feedsat,
    I managed to catch this signal-11658 V but no locked;first time with symbol rate 29994 Ks(3/4/16APSK), and the second time with 15992 Ks(2/3,8PSK):
    Best regards
    Hi Feedsat,
    Best Regards
    qwer.
    Oh boy, I´ve forgot this one...
    Thanks for the reminder, satesco.
    11659 V SR should be ~16000 (after several scans the same, only 1x SR 30000 scan) DVB-S2
    Tested 10 times, always 2 SR found (5 /10), the Sepctrum looks like a 30000 , not the half.
    30000 and 16000, maybe a new kind of TX ?
  • Today I have scanned several times this frequency with TBS6983 and TBS6908 cards.This time both cards have found only symbol rate of 29994 Mbps.
    We have the proof,if needed,the tool must be finished to lock signal on many frequencies which are not lock,but also to be more precise with the data it finds! I don't think I'm wrong that on 11568 V we have symbol rate of 30000 Ks!?!
    Couldn't it be a mux with PLS code, this is similar to other PLS mux, it show low SNR until you haven't found or type the correct PLS code.
    Don't you think so ?
  • Hi Feedsat,
    It seems as you say,but till we can't lock this signal, I can't tell you what type of transmission we have here.Take a lot of time to find out PLS code.I put Crazyscan to seek this code but found nothing.So I have been able to do today than to confirm that this frequency has this symbol rate!!!
  • I have the impression that tests are done on this transponder-11659 V, because again changed symbol rate;returned to 15996 Ks.This time at each scan was the same symbol rate.
    Confirmed by professional Satellites Technicians with professional analyzer: there are 2 carriers .
    WOW, thanks for that Feedsat!
    I never had expected this.
    Them too !
    Now: 11654 V 24000 16APSK
    Hallo :72:
    Viellleicht hast es schon mal gegeben , weiss ich nicht ; es ist aber das Erste mal dass ich einen Videofeed mit sr unten 1000 finde .
    Eutelsat 3C - 3.1E
    11675MHz - Vertical - SR: 899,837 Ks - 3/4 - DVB-S2 -8PSK
    TV-101
    schönen Freitag
    11655 V 24000 2/3 16APSK pilot: ON roll off: 0.35
    Sorry, can´t help... :91:
    Danke
