17.0°E Amos-17
  • I checked 13.4-13.75GHz in February and more recently. The method of comparing a scan to clear sky noise is quite sensitive but I have not found a hint of a signal. I was using an RHCP feed so should see V & H, although 3dB down. The attached plot just shows a slight increase from the base line due to a little ground noise.
    Amos 17 is supposed to have a European beam, possibly steerable, but I guess no-one has a use for it. Is there anyone further south that has seen anything?
    Ku wide band: corrugated conical feed, 1.5dB NF LNA, Ku (Standard): Octagon OSLO mod for C120 & ext ref Prodelin feed.
  • Nothing for me in spectrum, using 1.8m and chinese Extend Ku LNB. :126:
    [SIZE=1]/edit: nothing else can be found in spectrum (tried 70.5°E to 27.5°W)[/SIZE]
    Ku-band LNB: Invacom SNF-031
    If you want test the LNB, try https://www.satellitescommunit…d=&postid=38590#post38590
    You may just be able to detect it using CS. Set CS to not auto-range, with 1dB/div, and look for a small increase in noise level. The carriers at the centre of the humps are easily found using an SDR. USA-139 is inclined by about 8.5 degrees so can be hard to locate.
    https://www.n2yo.com/?s=25336
  • Since Amos-17 gives no results yet, maybe NASA's inclined TDRS relay satellites are worth a try? They use downlink band 13.4...14.05 GHz.
    In a quick search I found this pdf with detailed specs:
    https://ntrs.nasa.gov/archive/….nasa.gov/20180003065.pdf
    Visible from W. Europe are:
    11.4°W incl. 5.5° TDRS-13
    41.0°W incl. 4.6° TDRS-12
    46.0°W incl. 14° TDRS-6
    49.0°W incl. 14° TDRS-3
    62.4°W incl. 7.5° TDRS-9
