18.0°W Intelsat 37e
  • 3960 R,5333,9/20(26/45),S2X/16APSK,ACM-Data
    One more lock, using TBS 6903X:
    3904 L 30000
    /edit:
    Two more in circular right, using TBS 6903X:
    3953 R 6855
    3960 R 5332
    Probably they are in S2X? :64:
    Not new, but I´m sure about DVB-S2X and GSE (started this toppic in GS>S2X - merging above reports):
    3952 R 6855 and QPSK 9/20; 16APSK 23/36; 16APSK 25/36
    3960 R 5333 and QPSK 9/20; 16APSK 23/36; 16APSK 26/45 (reported satesco earlier)
    Today: 3953 R 6855 and DVB-S2X 16APSK 7/9
    3953 R 6855 (32APSK 32/45 today) and
    3960 R 5332 (also in DVB-S2 16APSK 3/4 today) are still activ in DVB-S2X.
  • 3953 R 6855 (32APSK 32/45 today) and
    my signal today with TBS5521::3:
    my C-band lnb is -3Mhz comparing other LNB s
    3950,R,6857,9/20,QPSK ; 3dB DVB-S2X
    3957,R,5334,9/20,QPSK ; 6dB DVB-S2X
    Einmal editiert, zuletzt von flie () aus folgendem Grund: correction circular ...changing "V" with "R"
  • 3953 R,6856,9/20,(S2X),ACM-Packetized(new),
    3960 R,5333,9/20,(S2X),ACM-Packetized(new).
    Both locked with tbs6590 card.
    /edit by qwer: merged in GS>C>S2X
    3953 R 6855
    3960 R 5332
    Both still on and also 3902 L 30000, but cannot lock it (13.5dB).
    PS: Spectrum in DX>C toppic.
  • Both transponders must be moved to the S2X Data section. I already know that you use the Tbs6903x card with Crazyscan and the parameters generated by the application give you Encapsulated stream,which can mean any type of stream.But in fact, in this case,3953 R and 3960 R,both are Data streams.I used for these transponsders the tbs6590 card and the same Crazyscan, but without making changes to the StreamReader.ini file and that means these streams are for Data.
    Besides,as a personal opinion,the Silab chip,like the one for the 6590 card,used by me,with the limitations we already know,knows how to handle better the received signal,but more importantly,it knows how to read correctly the parameters of a stream.For such a demodulator I don't even have to make modifications to FrameMode,in StreamReader .ini,like you have to do at 6903X to know what kind of stream is on a transponder.
    I am convinced that CrazyCat has made a compromise so that the StreamReader file can be used for the stid135 chip card and,as we already know,most of streams for Data are encapsulated.That's why he put them under the great umbrella of the Encapsulation,because this chip for tbs cards was "amputated" by STMicro,for reasons we can suspect...
    I scanned again 3953 and 3960 and the same Packetized stream as above at #7.
    Regards :3:
    Okay satesco done! :3:
