33.5°W Hylas 4
20.2005GHz Vertical linear feed
20700MHz on a linear feed so I don't know which polarisation. 1.2m dish, Gilat LNB.
5Ms/s
RHCP, 1.2m dish, Gilat band B LNB.
20700.000MHz linear polarisation (same level RH & LHCP)
20701.5MHz LHCP
LNB not GPSDO locked so frequency accuracy is not great. It's probably a plain carrier, the other lines are likely to be RX artefacts.
25.5°E Es'hail 1
20203MHz H
Note that this was using a band D LNB which is about 10dB down at this frequency.
GPSDO locked, the signal to the HF of the main one is a spurious.
37dB SNR in 10Hz, equivalent to 17dB in 1kHz. Taking into account the LNB, I would expect this to be at around 27dB SNR in 1kHz.
