17.0°E Amos-17
  • New:
    4090 H 30000 1/2 DVB/S2
    From what you can see in Germany it is available
    No signal in my position
    No signal (over 3,7GHz ) from Germany in C-band on Amos-17 with 4.9m, pawelwa. :301
  • Since coming into service I have monitored 17° E Cband on a regular basis here in the UK, about 17Km North of the City of Nottingham on my 2.2 PF but up to now have have only seen data signals on Hor and nothing at all on Ver.
    Here's the H data and beacon signals taken this morning (9th Aug. 20.)
    3683 H.
    3681 H.
    3679 H.
    3600.8 H.
  • I precisely adjusted the antenna to this position, the result is visible in the pictures:
    ... first lockable TV service for "European spot beam"?
    Linear signal (just my circular scan here - I will re-check signal/position in a few minutes):
    3928 and SR 1791 9/10 DVB-S2 8PSK Channels TV
    This one is in linear horizontal:
    3928 H 1791 9/10 DVB-S2 8PSK, Channels TV
    PS: 3837 H 1690 - GS?
    /edit 02.04.21: Pids
  • This one is in linear horizontal:
    Good Catch and Good News,
    To 103.0°E
    Thank you pawelwa for checking this beam! :73:
    Let´s wait for other reports in or out the "yellow zone" ...
  • Good signal level here from 17K North of the city of Nottingham UK on a small 2.2 PF.
    Also keeping an eye on 3933 H next to it.
    France
    but 9/10 needs a high level signal (crazy choice for such program....)
    Nothing appeared yet... :175:
  • 3928 H 1791 9/10 DVB-S2 8PSK ,Im best as ever :75:
    Kovosat 115cm, KaD band,
    DR HD F15,Octagon SF8008
    TBS 6983
  • 3928H unreachable for my 3 meters :88:
    But at 3724V I have a lock :36:
    1,8m "Prodelin" + VonWeise 24" (85E-34,5W)
    1,8m "Prodelin" + Egis Profi Tracker (polarmount mode testing)
    Edited 2 times, last by Lambda ().
    Sorry for my late reply Lambda,
    probably it is/was from circular position 12.0°E - according your scan...? We talked (not about 3724) earlier in this toppic, click!
    Nothing to lock for me in vertical scan.
  • Thanks for the advice, I will check this possibility. Do you have a signal on the 3925H? The parameters are the same as on the 3928H.
    Hi Lambda,
    there is only 3927.5 H - even when I can catch it on "3924 H" with CS too. :3:
  • I checked position 12.0E, you are right, 4 strong frequencies are reflected at position 17.0E
  • Only a little more is missing :3:
  • The signal is still on the rise :126:
    Edited once, last by Lambda ().
