New:
4090 H 30000 1/2 DVB/S2
From what you can see in Germany it is available
No signal in my position
New:
No signal (over 3,7GHz ) from Germany in C-band on Amos-17 with 4.9m, pawelwa.
Since coming into service I have monitored 17° E Cband on a regular basis here in the UK, about 17Km North of the City of Nottingham on my 2.2 PF but up to now have have only seen data signals on Hor and nothing at all on Ver.
Here's the H data and beacon signals taken this morning (9th Aug. 20.)
3683 H.
3681 H.
3679 H.
3600.8 H.
I precisely adjusted the antenna to this position, the result is visible in the pictures:
... first lockable TV service for "European spot beam"?
Linear signal (just my circular scan here - I will re-check signal/position in a few minutes):
3928 and SR 1791 9/10 DVB-S2 8PSK Channels TV
This one is in linear horizontal:
3928 H 1791 9/10 DVB-S2 8PSK, Channels TV
PS: 3837 H 1690 - GS?
/edit 02.04.21: Pids
Good Catch and Good News,
Signal on my place.
3928 H 1791 9/10 DVB-S2 8PSK - NO LOCKED
Good signal level here from 17K North of the city of Nottingham UK on a small 2.2 PF.
Also keeping an eye on 3933 H next to it.
Nothing appeared yet...
3928H unreachable for my 3 meters
But at 3724V I have a lock
Thanks for the advice, I will check this possibility. Do you have a signal on the 3925H? The parameters are the same as on the 3928H.
I checked position 12.0E, you are right, 4 strong frequencies are reflected at position 17.0E
Only a little more is missing
The signal is still on the rise
