11370 H,1749,5/6,Dvb-S2,ACM-Multi(21)
I hope I am not mistaken, but this transponder is on this satelit.I ask anyone to verify this(thanks in advance)The signal is high on many frequencies in orizontal pol but only on one I could lock.
Hi satesco,
thanks!
Feedsat has also locked this Frequency.
PS: I had to put this two threads together, a little later.
Of course I will check this signal soon as possible.
Best Regards
qwer.
Checked now 11370 H 1750 DVB-S2 MIS 21 too. :)
<Data>
Can any of you could check 11214 V , I have a signal very low with SR 10000 FEC 1/2
also data on 11370 H seems to be in a different modulation :)
QuoteOriginal von Feedsat
Same situation here on 11214 V.
Ok, thanks Qwer.
Maybe someone more in the east ?
New TPs switched on here. I can get only this for now... ;)
QuoteOriginal von marval450
Thanks marval450.
And that are my results of this evening...
Next one...
Nr. 3... :)) but stil very low signal,no picture.
10860 V... :)
Very bad situation on my south-western QTH with 2,2m.
I can "see" all these TP... with "NO LOCKED" signal
ähnlich, aber noch etwas schwächer hier die Signalausprägung; nur sporadisch zeigt der F16 ein kl. Signal unter 1,5dB an, das leider nicht bestehen bleibt.
Die 11235 und 11289 zeigen lt. OB vergl.weise einen interessanteren -dBm-Wert an, was aber auf das Signal keinen Einfluss hat.
Still very bad situation on my QTH with 2,2m.
"Strongest NO LOCKED" 11235 H 45000 1/2 DVB-S2 QPSK
Raw Data only for me...
3 TPs locked,at the moment. ;)
spectrum from France ;(
There are not enough smiley to share my sadness
Some promo here on 10735V.
Great thanks for this catch marval450!
Still a very bad situation here with 2,2m.
Scan of the day for my...dish I locked one of the transponders on spot India with 1.50 m dish:10789 V!
