65.0°E Amos-4
  • 11370 H,1749,5/6,Dvb-S2,ACM-Multi(21)
    I hope I am not mistaken, but this transponder is on this satelit.I ask anyone to verify this(thanks in advance)The signal is high on many frequencies in orizontal pol but only on one I could lock.
    Hi satesco,
    thanks!
    Feedsat has also locked this Frequency.
    PS: I had to put this two threads together, a little later.
    Of course I will check this signal soon as possible.
    Best Regards
    qwer.
    Checked now 11370 H 1750 DVB-S2 MIS 21 too. :)
    <Data>
    Can any of you could check 11214 V , I have a signal very low with SR 10000 FEC 1/2
    also data on 11370 H seems to be in a different modulation :)
    Same situation here on 11214 V.
    Ok, thanks Qwer.
    Maybe someone more in the east ?
    Original von marval450
    New TPs switched on here. I can get only this for now... ;)
    Thanks marval450.
    And that are my results of this evening...
    Very bad situation on my south-western QTH with 2,2m.
    I can "see" all these TP... with "NO LOCKED" signal
  • ähnlich, aber noch etwas schwächer hier die Signalausprägung; nur sporadisch zeigt der F16 ein kl. Signal unter 1,5dB an, das leider nicht bestehen bleibt.
    Die 11235 und 11289 zeigen lt. OB vergl.weise einen interessanteren -dBm-Wert an, was aber auf das Signal keinen Einfluss hat.
    1 Gib. 150
    1 T90
    1 Gib. 125
    Still very bad situation on my QTH with 2,2m.
    "Strongest NO LOCKED" 11235 H 45000 1/2 DVB-S2 QPSK
    Raw Data only for me...
    spectrum from France ;(
    There are not enough smiley to share my sadness
    Great thanks for this catch marval450!
    Still a very bad situation here with 2,2m. :35:
  • We have 2 new TPs here-
    11360 V 45000 DVB/S2 QPSK 1/2
    11414 V 45000 DVB/S2 QPSK 1/2
    (thnx pawelwa)
    After a long fight I have scanned 11414V,with F15. :11:
    All channels encrypted.(Background from other channel)
    Kovosat 115cm, KaD band,
    DR HD F15,Octagon SF8008
    TBS 6983
    Einmal editiert, zuletzt von marval450 ()
  • Scan of the day for my...dish :69: I locked one of the transponders on spot India with 1.50 m dish:10789 V!
