Just another look -via constellation monitoring- on:
10736 V 45000 1/2 DVB-S2 QPSK
10789 V 45000 1/2 DVB-S2 QPSK
10860 V 45000 1/2 DVB-S2 QPSK
(3-3.5dB more needed for a lock)
Lockable at my place 3 tp
...and here are the results from southwest Germany and 2.2m: zero points
10736 V 45000 1/2 DVB-S2 QPSK (-2.9dB)
10789 V 45000 1/2 DVB-S2 QPSK (-2.2dB)
10860 V 45000 1/2 DVB-S2 QPSK (-2.2dB)
Probably my personal best with -1.5dB and 2.5dB under LM on 10789 V 45000 1/2 DVB-S2 QPSK.
One is visible... 10860 V 45000 1/2 DVB-S2 QPSK with -2.9dB...
Very low signal at my place. satesco from Amos4 no Russian beams. Only Nepal and Africa
/edit by qwer: copy from GS>Ku toppic
My poor signal from southwest Germany and 2.2m on Nepal beam...
10736 V 45000 1/2 DVB-S2 QPSK (-2.8dB)
10789 V 45000 1/2 DVB-S2 QPSK (-1.9dB)
10860 V 45000 1/2 DVB-S2 QPSK (-2.0dB)
10914 V 45000 2/3 DVB-S2 QPSK (-10.0dB)
11235 V 45000 2/3 DVB-S2 QPSK (-2.0dB)
11289 V 45000 2/3 DVB-S2 QPSK (-10.0dB)
11360 V 45000 2/3 DVB-S2 8PSK (+0.7dB) - personal best, about 2.4dB under LM
No signal in high band on 12660 V and 12714 V, because GS signals from Intelsat 17 at 66.0°E.
There was nothing new(?) in my area except that I "scavenged" muxes with IQmonitor that seemed empty. What is found can be seen below on the spectrum.
As usual, Crazyscan always finds the same muxes.
I wonder if those who use IQmonitor find the same muxes I found. I don't know, but it should be confirmed. Even if they are with a question mark, it should be checked precisely because of that.
My current signal on 2.2m Nepal beam...
10736 V 45000 1/2 DVB-S2 QPSK (-2.3dB)
10789 V 45000 1/2 DVB-S2 QPSK (-1.6dB)
10860 V 45000 1/2 DVB-S2 QPSK (-1.0dB)
10914 V 45000 2/3 DVB-S2 QPSK (+0.7dB)
11235 V 45000 2/3 DVB-S2 QPSK (-1.9dB)
11289 V 45000 2/3 DVB-S2 QPSK (-2.9dB)
11360 V 45000 2/3 DVB-S2 8PSK (0.0dB) - only appearing parameter via BS
