21422 L 15000 3/4 QPSK2
ForsONEway
ForsONEway
Scan from 20.12.2013
QuoteOriginal von Feedsat
Still there!
PS: Test with linear polarisation, "NO LOCKED" signal.
Bad signal now for Nilesat 201 KA Band beam
Test (linear vertical).
Bad scan of the day...
21462 L 22500 is finally unlocked today, VERY WEAK but there is something
21462 finally locked but VERY WEAK
21422 L has left
Great Feedsat!
21.421GHz is a carrier with SNR of 12dB in 1kHz and 21.462 is only just detectable at 2dB in 100kHz. Using a Gilat PLL, linear polarised (H or V the same) and 1.2m offset.
QuoteOriginal von s-band
Analyser plot of the above
Gilat LNB, Linear feed, 1.2m
I looks like the 2nd TP is back and possibly the opposite polarisation to the carrier
...21421 V (here: linear vertical scan)
Circular scan today with 1,8m - to be confirmed... (but it looks real, always same parameter in different scans - incorrect FEC) - on again:
21421 L 22500
/edit: DVB-S, I think
21421 L 22500
Which FEC should I choose for "smooth -10dB-lock" or is it 1/2... ? (joke)
(joke)
Even if it's a joke,I go into the game and say that the greater chance of locking the signal is with fec 2/3,of those that appear on one of the spectrum.Joke or not,under other favourable conditions (weather),in qpsk mode,I say you will lock this transponder at a time you do not expect.Let the One from Above hear
... a litttle closer to the signal after "one-million-clicks", showing FEC 2/3 (edit: or 3/4 or 7/8) in first (/second/third) "smooth lock" (to be confirmed by constellation monitoring)
Next step: positive SNR (still not sure about FEC, must wait for manual lock...)
You can try with IQ monitor...
Okay, getting correct parameter this evening:
21421 L 22500 5/6 DVB-S
