09.0°E Ka-Sat
    Scan L & R
  • Hi Feedsat,
    I use Inverto Twin(for Saorsat)to scan Ka-band at 9.0° East.I think on this satellite is a transmission on a single polarity-Left,even if analyzer find also transponders on Right pol?!?On your RF, symbol rate on right pol is slightly bigger, but I doubt that is accurate as long as the signal can not be lock!
    Of course that I haven't received the signal from Irish transponder.
    My regards
    ps-Frequencies that I've found do not match with yours!
    Einmal editiert, zuletzt von satesco ()
    Hi Satesco,
    Thanks for your scan but as you know this KA satellite is different to others because of its 82 spotbeams, we may not have the same scans all around Europe (if you have a look to dx club , you will found something different as you and me from Germany) .
    and also the frequencies are not exactly the same .
    This satellite is used for "Sat2Way" and NewsSpotter" for newfeeds (in IP) .
    I confirm the two polarizations are used on my spot beam but should be not the same for someone in an other spot beam than mine,in France.
    3 Mal editiert, zuletzt von Feedsat ()
    Hi "Ka-band-guys"! :D
    it´s very windy today and I never thought to install Ka band on this day here. But I can´t wait anymore...
    I´m using Inverto Twin WHITE Ka Circular Dual Polarity LNB with" selfmade" flange.
    Here my today first scan from my region.
    PS: Please check Ka Satellites List
    Am I right with regions?
    EDIT: Sorry for my wrong scan here earlier!
  • With the same LNB(Inverto Twin White),it is clear that both received signal from two beams,only that one is stronger than at the other.Do not ask me on that beam.Unfortunately a polarity signal is affected by interference today.
    I mention that I've done the test on a rainy weather.
    ps_20218 missing on your spectrum.Where is it?
    2 Mal editiert, zuletzt von satesco ()
    Today's scan
    You could put the correct name spot beam to be more accurate in your list ?
    http://www.satbeams.com/satellites?norad=37258
    4 Mal editiert, zuletzt von Feedsat ()
    Thanks, Feedsat! Done. :)
    Hi,
    I´m editing attached files (scans) from my first post here.
    Scan of the day.
    Good weather conditions - less signal on left polarity.
    Got them all now (all "NO LOCKED").
    Changing SR: 19995 R 50000 DVB-S2 now
    Scan of the day.
    Nothing new here.
    Scan of the day.
    Nothing new here.
    Same.
  • I'm wondering how these newsspotter IP feeds work.
    I don't have a Ka-Band LNB to check, so are there also signals with lower SR or only those signals with 50-51 MS/s that can't be locked by us.
    In the US it seems IP feeds are very popular and so the IPCleaner tool was published to extract the stream out of it so that it can be played by vlc for example.
    19794 L SR 52000 DVB-S2 now
    19994 R SR 52000 DVB-S2 now (here too)
    19919 L 52000 DVB-S2 changing parameter
    20180 R 52000 DVB-S2 changing parameter
    Two frequencies not possible to scan for me right now.
    My first try on this one, with 1,2m and position 04.8°E in focus, but nothing new.
    Not all can be "NO LOCKED" here... :83:
    Update for my region, changing SR:
    19857 L 52000 DVB-S2, unlocked
    Getting all as usally "No Locked" today with 1.2m (L4.2).
    Nothing new.
    Scan of the day, but nothing changes here.
    No changes here.
    Just to have a look on this unlockable position. No changes.
