• current scan
    Suedschwede Setup
    > 2x AX HD51 4k
    > 2x SF 8008 Twin
    > 1x SF 8008 Mini
    > 1x SX 88 V2 Dual
    > 1x Edision Os Mio 4k
    > 1x OpenboxSX6
  • Thank you for your report Suedschwede! Great!
    Just for fun at my place:
    12653 V 35007 2/3 - aprox 10.0dB less signal, according different setup/place in comparison to Suedschwede:72:
    PS: I had much weaker signal today in complete spectrum (as in my last scan here).
  • Southern beam from ABS2. At good weather and time also receivable BFBS mux on 12730H. Thks that they low FEC. :12:
  • 12526 H,35000,3/48PSK-STV,(Eduard on FlySat),
    12652 H,35000,44950,4/5-GeoTelecom(Torrex12 & Eduard on FlySat) :3:
  • Here's my very poor situation from my place for ABS 2 and 2A
    Russian and Southern Beams are not possible and nothing interceptable with my current setup
    Showing same spectrums from both ABS 2 and 2A different positions
    RotorFeed: C LR/HV+KU H/V
    TBS5925-6983+6908
    RC2000C
  • There is no news in my area at 74.9E, even though the signal is slightly better.
    So, I'm on the "chart" with my 1.50m antenna. :51:
  • Probably someone else can clarify....? :175:
    11801 V 45000 (-2.4dB) -> locked GS 11801 V 12725
    11860 V 45000 (0.5dB) -> locked GS 11864 V 4000
    PS: I think these GS locks are from ABS-2 ... same as superdish66 scans above.
    In my area, I haven't found the two muxes you mention. :3:
    More than likely the signal is coming from a southern spot, which my antenna cannot pick up. :25:
  • Southern spot or CAF spot?
    Of course, I can't be sure of the source of the signal if I can't get these two muxes.
    Satellite coverage maps may not be enough to identify the signal we are picking up. Some are no longer updated. That's why having more reception reports from more geographical areas is good.
    We also need to know that besides the list of satellites on FlySat, Lyngsat, etc., some are not listed here, which could also be a source of the signal we cannot identify. This is made from reports from hobbyists, as they say, contributors.
    And there are quite a few satellites that are not on these lists.
    Our colleague, hvdh, had, or has, a site with "Geostationary Satellites from 80° W to 120° E". I tried to access it a few times, but I couldn't.
    So, the problem is not the signal we receive but the source of information and verification of what we are receiving. That's why we sometimes get caught in the fog.
  • Our colleague, hvdh, had, or has, a site with "Geostationary Satellites from 80° W to 120° E". I tried to access it a few times, but I couldn't.
    Since 2021 the URL is https://gso-satellites.nl/
    It's also in the pull-down menu here on satellitescommunity!
  • Today lock on the limit Southern beam again! Signal is very fluctuating.
    Only TBS6904SE can lock this tp!
