Today on 12547 V 1900, MIS 170.
30.5°E Arabsat-5A <Pan-Arab>
On again with known TC (12547 V 1900, MIS 170).
New for the list:
12696 V 3500
On again after a long time, 12666 V 1000 and new here, but unlocked, 12667 V 1000.
Indeed, 54000 is a new symbol rate ( KooLy & feci01 on FlySat)
12546 V 1192 and MIS 170 (4:2:2)
On again after a long time. Black screen at this time. Too low signal for clear video earlier.
This publication of a respected @qwer interested me very much, because. ArabSat-5 is a top satellite for me,
but my antenna is outside the coverage area, and its aperture is 2 times smaller (gain -12dB).
Will I be able to receive and recognize the signal using the IQmonitor Pro 1.0.2.5 program?
I moved the antenna using USALS to the position 30.5°E and this is what I got:
On horizontal polarization, everything is much more deplorable:
But in vertical polarization, three transponders were found, and SR, unlike CrazyScan, was calculated exactly by the program.
Though under the threshold of the lock
very impressive results, knowing where you live and the size of your antenna.
очень впечатляющие результаты, зная, где вы живете и размер вашей антенны.
on my side, I sometimes have some difficulties to choose the right frequency to make the feedreport
Meiner Seite's habe ich manchmal Schwierigkeiten, die richtige Frequenz zu wählen ,um den Feedreport zu machen.
На моей стороне, я иногда испытываю трудности с выбором правильной частоты для выполнения отчета о питании.
