5G vs. C-band
  • Hello,
    I would like to open this topic to share experiences and tips for 5G and C-band interference.
    In Hungary 5G network installation has been started below 3.8 GHz.
    Some DX-er reported near 5G tower (around 5km) C-band almost totaly died. Over 3.8GHz as well.
    So if somebody has some similar experience or solution, please share in this topic.:3:
  • here from me below 3600 ghz no signal, here is the wimax covering the C band
    Lodi sud
    dish 150 gibertini
    lnb ku fracarro
    lnb ka inverto
    lnb C L+R supermax
    lnb C v+H supermax
    1 motor smr 1224 geändert
    2 motor El
    tbs 6925 sat
    tbs 5280 Dtt
    rover tab 7 EVO
    proform KTI h 180 x back up smr 1224
  • Sky and star watchers have gone far from urban areas due to light pollution, I guess the same is expected of C band fans due to the 5G network :88:
    3,1m "Metalski Zavod Tito" PF (91.5E-47.5W)
    2,7m "Laminas" offset (UK 28,2E)
    3x 1,8m "Prodelin" offset
    1,2m "Channel Master" offset + Amiko DM3800S (90E-55,5W)
    TBS5927;TBS5925;Octagon SF8008;DM8000
  • The ADE antenna helped me against interference in the C band.
    Spectrum interference on prime focus antenna
    and ADE antenna, spectrum almost without interference.
    TBS5925, TBS6983, TBS6903, TBS6903x, TBS6903x V2, TBS6522, TBS5520SE, TBS5927, TBS5590, Prof7301, PF 250cm, ADE antenna 370cm, Full band LNBs: S, L, C Norsat PLL ,X PLL, Ku NJR2842S PLL, full Ka band PLL, and other iron for DX reception, 53W - 98E.
  • What's an ADE antenna?
    ADE = Axis-Displaced Dual-Reflector Antenna
    It is an antenna with a secondary reflector, similar to a cassegrein or gregorian. The difference is in the picture. These are high efficiency antennas.
  • Hi newsy,
    This is an antenna from NWIEE, originally for X band Transmit and C band Receive.
    After appropriate modification, I use it for all frequency bands, C, X, Ku and Ka. I'm still tweaking it. However, it may not be as accurate for the C band. But even so, its gain is slightly better by about 1 to 1.5-dB compared to a prime focus antenna of the same diameter. The immunity to LTE internet interference is very good.
