Lockable today:
11688 H 1110 3/4 DVB/S2 8PSK
01.0°W Intelsat 10-02 <S2 ME>
Breaking records...
11688 H,1110,3/4,8PSK-Hona Baghdad atm
My signal...
11464 H,133,5/6,QPSK-r (probably Arab(?) radio)-new
11464 H,133,5/6,QPSK-r (probably Arab(?) radio)-newNO LOCKED on my place.
Original von pawelwa
I'm sorry you didn't make it right now.I'm sure at another time, you'll succeed,because the signal has fluctuation.For that very reason,you will be able to lock it At such a moment,I also locked it with 110cm antenna.
regards -
11690 H,1400,5/6-TV101,
11689 H,1115,3/4,8PSK-Hona Bagdad,again locked -
11689 Hor - Hona Baghdad
11688 H-Strong signal,over 9.0dB,on Hona transponder.
11465 H,133,5/6-is active,radio program is on
Hier mit 1,8m nur ein Signalrest...
I'm not sure that the symbol rate at 11193 is still valid now,but it seems that the symbol rate and the frequency have changed,now at 11190 H,1200,5/6,8psk,too weak signal to lock it.It needs to be checked.
I also post what I got with IQmonitor,but I'm not sure that the frequencies and symbol rates are correct
I (re)checked the above frequencies with IQmonitor.As you can see,the same symbol rate at frequencies found.The result is inconclusive
Lockable today:
11194 H 1600 8/9 DVB-S2/8PSK
11689 H,1115,3/4,8PSK-Hona Bagdad,again locked11690 H,1200,5/6,8PSK-TV101-new symbol rate
11688 H,1110,8/9,8psk-Hona Baghdad,
11033 H,2300,3/4,8PSK-again
11193 H,1600,8/9-nolock
