C Band California Amplifier 17K 3700/4200
  • Hallo ,
    Kennt jemand von euch diese Art von C Band LNB?
    Ich weiss , dass es nur von 3700 bis 4200 geht ,
    ist es aber eine gute LNB ?
    Das beste ist selber zu probieren , ich weiss es
    Winter ist aber dafür nicht ideal.
    Wenn jemand schon mit solche LNB Erfahrung hat, bin ich ganz Ohr
    Hello
    Do any of you know this type of C band LNB?
    I know that it's only possible from 3700 to 4200,
    but is it a good LNB?
    The best is to try it yourself, I know it
    But winter is not ideal for this.
    If someone already has such LNB experience,
    I would be happy to read them
    Stephan94
  • This LNB is standard. Although it has the above range from 3700MHz, it can easily handle lower frequencies. Given the gradual interference of the band below 3.7GHz from LTE internet, this range will be an advantage rather than a disadvantage.:426:
    TBS5925, TBS6983, TBS6903, TBS6903x, TBS6903x V2, TBS6522, TBS5520SE, TBS5927, TBS5590, Prof7301, PF 250cm, ADE antenna 370cm, Full band LNBs: S, L, C Norsat PLL ,X PLL, Ku NJR2842S PLL, full Ka band PLL, and other iron for DX reception, 53W - 98E.
  • Guten Morgen Peon :74:
    Vielen Dank :73:
    weiss Du ob diese LNB durchschnittlich ist oder gut oder schlecht in Sache Empfindlichkeit ?
    Thank you very much :73:
    do you know whether this LNB is average or good or bad in terms of sensitivity?
    Franzose in Franken
    1200LaminasD/1.20CM F
    TBS5925+6983 Openbox SX6 ; Edision MIO4K ;LNB Octagon PLL
  • It is a common commercial DRO LNB. Its properties are at the level of the average. They can also vary from piece to piece. The features of the NJS8486 series or Norsat 8115 cannot be expected. But they are suitable for normal use. :61:
