European micro launcher
  • Satellite technologies are developing so rapidly, it is not surprising that new rockets are emerging to launch them. CubeSats, 6g, satellite internet, satellite TV, etc. All of this requires tools to launch into space. I recently found a new European micro launcher for myself.
    Skyrora has done tests and is looking forward to launching soon.
    I hope they succeed. Then we could get a new satellite launch operator. I wonder what benefits this might have for launching small satellites?
  • Antennen für die CubeSat-Kommunikation von
    Veljovic, Miroslav
    2020
    Two antennas got married on a roof.
    The ceremony wasn’t much,
    but the reception was excellent!
    (unknown author) )
    https://infoscience.epfl.ch/re…511/files/EPFL_TH7489.pdf
    Résumé
    CubeSats are a type of small satellites (< 500 kg) that weigh several kilograms and consist of multiple Units (U) measuring 100 × 100 × 113.5 mm3. CubeSats emerged as a low-cost alternative to conventional large satellites, and have since demonstrated capabilities for communication, Earth observation, technology demonstration and many other. The primary goal of CubeSats, as it is the case with any miniaturized satellite, is to reduce the cost of orbital deployment. CubeSats are commonly launched as a secondary payload on large launch vehicles. One or several satellites are placed in a dedicated deployment system, which typically accommodates three CubeSat Units. The deployment system strictly limits the dimensions of any features on the CubeSat surface. CubeSat antennas perform the same functions as antennas on conventional satellites, such as telemetry and command, communication, navigation or inter-satellite links (ISL). However, most traditional antennas for small satellites are not suitable for CubeSats due to the profile constraints of the deployment system. Two approaches for antenna design are generally adopted. In the first, one or several low-profile antennas are placed on the CubeSat exterior. In the second, deployable antenna structures are used if the CubeSat platform does not offer sufficient dimensions. At low frequencies, the additional space is required to achieve a good radiation efficiency, whereas at high frequencies an increased antenna aperture provides a high gain. This thesis describes several antenna geometries, both low-profile and deployable, which enable several communication aspects of an Internet-of-Things (IoT) constellation of 3U CubeSats in the Low Earth Orbit (LEO). The main novelty of the proposed solutions is in their electromagnetic performance, as opposed to most CubeSat antenna designs where the mechanical design is the main achievement. The presented antennas succeed to exhibit a wide bandwidth or a specified radiation under strict size constraints. The thesis presents several wideband aperture-coupled patch antennas for TT&C and data downlink in S and X bands. A thoroughly investigated shielded-stripline feeding structure enables a wideband circular polarization (CP) with a unidirectional radiation, and demonstrates capabilities such as interference suppression of adjacent frequencies and efficient CubeSat integration. Patch-antenna arrays in L band are then presented, which radiate several independent beams for the capacity increase of an IoT machine-to-machine (M2M) communication system. The high permittivity of the antenna substrates lead to a strong coupling to the 3U CubeSat structure, emphasizing the importance of the antenna placement. Finally, different configurations of high-gain fixed-beam reflectarrays (RA) and transmitarrays (TA) are for the first time proposed for CubeSat ISL LEO communications in K band. Two novel unit cells are presented for RA and TA antennas, based on coupled loops and aperture-coupled patches, respectively. An axially corrugated CP horn antenna is designed as the feeding element for the arrays. A prototype of this antenna is fabricated using additive manufacturing in aluminum. The performance of all antennas, presented in this thesis, is validated by agreements between the calculation and 3D-simulation results and the VNA and anechoic-chamber measurements of several prototypes.
    Détails
    CubeSats sind kleine Satelliten (<500 kg), die mehrere Kilogramm wiegen und aus mehreren Einheiten (U) mit den Maßen 100 × 100 × 113,5 mm3 bestehen. CubeSats hat sich als kostengünstige Alternative zu herkömmlichen großen Satelliten herausgestellt und seitdem Fähigkeiten für Kommunikation, Erdbeobachtung, Technologiedemonstration und viele andere demonstriert. Das Hauptziel von CubeSats ist, wie bei jedem miniaturisierten Satelliten, die Reduzierung der Kosten für die Bereitstellung im Orbital. CubeSats werden üblicherweise als sekundäre Nutzlast bei großen Trägerraketen gestartet. Ein oder mehrere Satelliten befinden sich in einem dedizierten Bereitstellungssystem, in dem normalerweise drei CubeSat-Einheiten untergebracht sind. Das Bereitstellungssystem begrenzt die Abmessungen aller Features auf der CubeSat-Oberfläche streng. CubeSat-Antennen erfüllen die gleichen Funktionen wie Antennen auf herkömmlichen Satelliten. wie Telemetrie und Befehl, Kommunikation, Navigation oder Inter-Satelliten-Verbindungen (ISL). Die meisten herkömmlichen Antennen für kleine Satelliten sind jedoch aufgrund der Profilbeschränkungen des Bereitstellungssystems nicht für CubeSats geeignet. Im Allgemeinen werden zwei Ansätze für das Antennendesign angewendet. Im ersten Fall werden eine oder mehrere Low-Profile-Antennen an der Außenseite des CubeSat angebracht. Im zweiten Fall werden einsetzbare Antennenstrukturen verwendet, wenn die CubeSat-Plattform keine ausreichenden Abmessungen bietet. Bei niedrigen Frequenzen wird der zusätzliche Raum benötigt, um eine gute Strahlungseffizienz zu erzielen, während bei hohen Frequenzen eine erhöhte Antennenapertur eine hohe Verstärkung liefert. In dieser Arbeit werden verschiedene Antennengeometrien beschrieben, die sowohl unauffällig als auch einsetzbar sind. die mehrere Kommunikationsaspekte einer Internet-of-Things-Konstellation (IoT) von 3U CubeSats im Low Earth Orbit (LEO) ermöglichen. Die Hauptneuheit der vorgeschlagenen Lösungen liegt in ihrer elektromagnetischen Leistung im Gegensatz zu den meisten CubeSat-Antennendesigns, bei denen das mechanische Design die Hauptleistung ist. Den vorgestellten Antennen gelingt es, unter strengen Größenbeschränkungen eine große Bandbreite oder eine bestimmte Strahlung aufzuweisen. Die Arbeit präsentiert mehrere Breitband-Apertur-gekoppelte Patch-Antennen für TT & C und Daten-Downlink in S- und X-Bändern. Eine gründlich untersuchte Speisestruktur mit abgeschirmter Streifenleitung ermöglicht eine breitbandige Zirkularpolarisation (CP) mit unidirektionaler Strahlung und demonstriert Fähigkeiten wie die Unterdrückung von Interferenzen benachbarter Frequenzen und eine effiziente CubeSat-Integration. Anschließend werden Patch-Antennen-Arrays im L-Band vorgestellt, die mehrere unabhängige Strahlen für die Kapazitätserhöhung eines IoT-M2M-Kommunikationssystems (Machine-to-Machine) ausstrahlen. Die hohe Permittivität der Antennensubstrate führt zu einer starken Kopplung an die 3U CubeSat-Struktur, was die Bedeutung der Antennenplatzierung unterstreicht. Schließlich werden für die CubeSat ISL LEO-Kommunikation im K-Band erstmals verschiedene Konfigurationen von hochverstärkten Feststrahl-Reflektarrays (RA) und Transmitarrays (TA) vorgeschlagen. Für RA- und TA-Antennen werden zwei neuartige Einheitszellen vorgestellt, die auf gekoppelten Schleifen bzw. Apertur-gekoppelten Patches basieren. Eine axial gewellte CP-Hornantenne ist als Speiselement für die Arrays ausgelegt. Ein Prototyp dieser Antenne wird unter Verwendung der additiven Fertigung in Aluminium hergestellt. Die Leistung aller Antennen,
