12.0°E Blagovest 4
  • Thanks for help Feedsat in this toppic here, click!
    feci01 locked already some frequencies...
    Here are my scans in circular... some appeared on both polarities... sorry! :77:
    All GS.
    Today: 3852 R 1150
  • 2TPs locked here.
    Kovosat 115cm, KaD band,
    DR HD F15,Octagon SF8008
    TBS 6983
  • I can´t remember about such a strong signal 3873 R 2500 with >26dB!
    Also new: 3876 R 2000 (24.5dB)
  • For now,I'm scanning Amos 17 for the first time with (sorry)circular lnb.Unfortunately,there's a lot of spikes ups and downs(several,which is not good),which doesn't surprise me.I have a little satisfaction that I still found some transponders. I didn't expect these either,in case it didn't come from a nearby satellite.
    Even if I'm not sure,I'll post the only transponder locked(stream generic), which I found and that is not reported above. Please correct me if it is wrong. And if it is on this position,moved to the GS section.Thanks.
    3876 H(V),2000,2/3,S2,ACM,GS.
    added:Unfortunately I have to correct myself,because 3876 V,2000,2/3 is not on Amos-17,but on Eutelsat 10A,with an incredible signal,over 21dB.That's why irradiation touches other positions.
    3876 H,2000,2/3,S2,ACM,GS.
    Hi satesco,
    it´s (probably) from Blagovest 4 @12.0°E :71:
  • Hi satesco,
    Thanks for info. If so,then please move my post to the right topic.Thanks again.
    So I'll have to be very careful what the transponders find at 10.0E,which,my small antenna does not discriminate close positions,especially when the signal is very strong,like this one :25:
  • Hi satesco,
    Indeed 3872 V is on this satellite with a very strong signal. I scanned it now and found also 3794 V/H 15400,2/3,on both polarities.It's true that I use circular lnb,but I don't think it's a problem since 3872 V uses a single polarity.I didn't find any other transponders, but only one,probably carrier test(?) :3:
    ...27.0dB at this time. :79:
  • New for the list: 3893 L 10950
  • New for the list:
    3868 R 500
  • Nothing new lockable - two months later...
  • A new scan with some changes - so strong and some appearing on the other polarisation here too...
    3868 R 300
    3872 R 1500
    Scan of the day. Some changes: 3845 R 2000 - 3917 R 1800 - 3924 R 4000 - 3928 R 3000
    And unlocked: 3652 R 4000 (2/3 DVB-S2 8PSK)...
    Today:
    3794 R 15400 (on both polarities)
    3872 L 1500 (on both polarities)
    3917 L 1800 - new
    3923 L 1600 - new
  • I cannot remember a stronger signal:
    3868 R 2400 - 28.0dB over LM :45: ... appeared also in opposite polarisation (for me) - new
    3532 R 1100 - new, appeared also in opposite polarisation (for me)
    3604 R 1500 - new, appeared also in opposite polarisation (for me)
    3708 R 2400 - new, low signal
    3726 R 450 - new
    3880 L 2000 - new, but empty carrier (TS)
  • ...two more:
    3898 R 300
    3899 R 300
  • Four for the list:
    3549 R 2500
    3862 L 1000
    3927 L 1600
    3933 R 300
  • New here:
    3908 R 300
    Also using now circular left:
    3550 L 2500
  • Breaking news...sorry, only joking...
    probably new:
    3760 R 1200
