12.0°E Blagovest 4
Today: 3852 R 1150
I can´t remember about such a strong signal 3873 R 2500 with >26dB!
Also new: 3876 R 2000 (24.5dB)
For now,I'm scanning Amos 17 for the first time with (sorry)circular lnb.Unfortunately,there's a lot of spikes ups and downs(several,which is not good),which doesn't surprise me.I have a little satisfaction that I still found some transponders. I didn't expect these either,in case it didn't come from a nearby satellite.
Even if I'm not sure,I'll post the only transponder locked(stream generic), which I found and that is not reported above. Please correct me if it is wrong. And if it is on this position,moved to the GS section.Thanks.
3876 H(V),2000,2/3,S2,ACM,GS.
added:Unfortunately I have to correct myself,because 3876 V,2000,2/3 is not on Amos-17,but on Eutelsat 10A,with an incredible signal,over 21dB.That's why irradiation touches other positions.
Hi satesco,
it´s (probably) from Blagovest 4 @12.0°E
Thanks for info. If so,then please move my post to the right topic.Thanks again.
So I'll have to be very careful what the transponders find at 10.0E,which,my small antenna does not discriminate close positions,especially when the signal is very strong,like this one
Hi satesco,
Indeed 3872 V is on this satellite with a very strong signal. I scanned it now and found also 3794 V/H 15400,2/3,on both polarities.It's true that I use circular lnb,but I don't think it's a problem since 3872 V uses a single polarity.I didn't find any other transponders, but only one,probably carrier test(?)
...27.0dB at this time.
New for the list: 3893 L 10950
I cannot remember a stronger signal:
3868 R 2400 - 28.0dB over LM
... appeared also in opposite polarisation (for me) - new
3532 R 1100 - new, appeared also in opposite polarisation (for me)
3604 R 1500 - new, appeared also in opposite polarisation (for me)
3708 R 2400 - new, low signal
3726 R 450 - new
3880 L 2000 - new, but empty carrier (TS)
New here:
3908 R 300
Also using now circular left:
3550 L 2500
Breaking news...sorry, only joking...
probably new:
3760 R 1200
