ZitatOriginal von marval450
4100 L 20000 2/3, TNT Niger left...
Now I have also nothing.
edit: 1 hour later, tp back on, more than 2 dB stronger than before during evening hours
Since yesterday the Niger mux on 4101 L is much weaker. On my 230cm mesh it´s now around lock @ 6,4dB.
4088 L 3329 (QPSK 3/4) is new with good signal: Tele Sahel (only 1 channel + radio)
My monsterous signal , Badr has strong interference here somehow.
4102-2,5db
Since yesterday afternoon 4102L is better again
4088L still active (seems to be switched from 5W)
changing frequency for Tele Sahel, now on 4117 L 3330 (4088 L is off).
edit 23 June:
4117 L off, 4088 L 3330 back on again
The 4117 L is only active with football matches "Africa cup of nations" in Egypt.
edit 23 June
Tele Sahel promotes the 4101 L 20000 as "C Band High Power EMEA"-beam, so it's probably not 'Medium Power' (flysat/lyngsat).
My signal on new T.Sahel fr.
4102 L no lock(2m).
No signal on T.Sahel atm.
Finaly 4102 L works on 2m here.
T.Sahel is also on.
TeleSahe and TNT Niiger captured in my area with 150 cm antenna.Also with DM920 UHD
Today extreme power 4101L. Previously 50-60% with VU+Zero4K, now 90-98%.
The last days, I had 4101 L with 11,5 dB and 4088 L with 10,5 dB (mesh 230). Very stable signal.
4101L operation is very poor. Signal is OK, but most of channels black screen every time. Only Tele Sahel and Tenere TV has transmission.
Is there somebody at the control room
my signal
4100,H,20000 8psk 2/3 ...10.3dB
4085,H,3330 Qpsk1 3/4...5.8dB
A single transponder with the Tele Sahel channel at the reception limit.
And the transponder 4102 L 20000 works great
Antenna 240cm
