96.5°E Express-103
I checked the upper band (12500-12750 V) to see if the muxes on 96.5E are still active. As you can see, not only are they there, but this time IQmonitor confirms their presence between 12500-12525 V.
From your spectrum, I see that the signal in your area is not good enough to check the upper band. That's why ask DX Bozoth to keep looking for these muxes. Thanks.
Below is the signal I'm receiving in my area at 96.5E:
Kind regards
ps_I checked the upper band at 96.5E and with neumoDVB under Linux. I do not doubt that the muxes found there are at this position.
11644 H,6800,3/4,32APSK,ACM-new GS,
...11005 v,1500,1/2,S2-GS,new symbol rate,
11003 V,5000,2/3,8PSK-GS, new
11024 H,12500,3/4,16APSK-GS, new,
11062 V,3500,3/4,8PSK-GS, new symbol rate (on FlySat),
11505 H,3712,2/3,8PSK-GS, new symbol rate,,
11621 V,5180,1/2,S2-GS, new,
11646 H,4141,1/2,S2-GS, new symbol rate.
11505 H,3712,2/3,8PSK has left,
11520 H,2540,1/2, S2-GS, new,
11531 H, 4300, 2/3, 16APSK- GS, new,
11618 V,4000, 1/4, S2-GS, new symbol rate.
11531 H,3500,3/4,16APSK- GS, new symbol rate,
11618 V,4000,1/4,S2 has left,
11001 V,4200.2/3,16APSK- GS, new symbol rate,
11062 V,5500,3/4,32APSK- GS, new symbol rate,
11089 H, 18200,2/3,S2- GS, new symbol rate,
11691 H,5557,5/6,16APSK -GS, new.
Thanks, N_Stanislav, for posting the signal and transponder spectra from the extreme, low-elevation satellites, and all the ones you visit. It's important to know how spots in other geographic areas manifest.
I will post two new transponders right here on the forum, although they are on your spectrum and not reported anywhere else.
11160 H,33192,5/6,16APSK, Multi 21-Data, new,11675 V,37502,1/2, S2, Multi 1⇾254_GS, new.
11546 V,6308,2/3,16APSK-GS, new,
11559 V,3526, 5/6,16APSK- GS, new,
11546 V and 11559 V have left.
11105 V, 44080, 1/2, S2,Multi 1~254 -GS, new
