• Hello.
    i´m new here but not new in Sat Reception. Since i moved to another appartment i only have a community satellite system with 19,2, 13 and 42° East.
    i wanted to try the data Channels 12670v at Astra and 11471v, 16Apsk at Hotbird. But no succes with my TBS6925.
    Could anybody check this 2 frequencies if still active?
    thankyou.
  • Hi keyhole,
    welcome to the forum. :3:
    12670 V is very weak here (unlocked).
    11471 V from position 13.0°E has left :25:
    FYI: Changed toppic name.
  • qwer April 30, 2021 at 8:39 PM
    Changed the title of the thread from “19,2 E/13 E Data” to “19.2°E Astra 1N”.
    South-west Germany, click!
  • ok. me West Austria.
    Why is 12670v weak? should be European Beam.
    12670 V has good signal,but it does not lock because(that's my guess) it probably has a MIS or PLP code(?).Or,at least,probably,it has another transmission standard.Which I don't believe myself,but,who knows,it's not excluded.But I think it's about transmission codes.
    The signal is very strong in my area,Romania,even with a 110cm antenna!The signal is the same, weak,(the same on all areas of Europe),regardless of the size of the antenna!!!
  • Has anyone tried to get LOCK on 11567.50V and 11626.50V?
    PS: 11141.25H - maybe GSE-HEM from 11023H
    Edited once, last by EnoSat (November 15, 2023 at 10:26 PM).
  • keyhole
    12670 V is a SES Transponder
    EnoSat
    No lock on both transponders tested with different cards
    TBS6903x
    TBS6904SE
    TBS6908
    but found this on 11649 V
  • Die oben genannten Transponder sind auf Flysat gelistet, aber ohne Daten.
    These transponers are listed on flysat, but without data.
  • 11649 V war wohl nicht gemeint.
    Bei diesen Signal dürfte es sich um ein zirkulares 8QAM handeln.
    This signal is probably a circular 8QAM.
