40.5°W SES-6
    3655 R 605 looks like a MIS stream... ?
    Not new
    4150 L
    4038 L 1370 is also on air
    Same here...
    Hi Feedsat,
    this evening I found something out...
    CrazyScan has problems to lock sometimes MIS streams, even if the signal is pretty enaugh... This is not new, I know.
    My trick:
    1. Go first on a lockable carrier and lock it by opening "Constellation monitoring".
    2. Than let "Constellation monitoring" opened and put the "NO LOCKED" data in: Frequency, Polarization, SR.
    3. Click in "Blind Scan" field, as you do when you do a "hard lock" (look at attached file).
    4. This is the important step! Than click "Update modulation info" (look attached file).
    5. Now all is done and you can click to try to lock this frequency.
    6. Good luck!
    For me, it works on that carrier! Now I had to test some more of them...
    ... and a second carrier behind that ^^^
    3657 R 1210 DVB-S2 MIS 1
    PS: I don´t need a trick here.
    Nice trick !
    I will have a look later
  • 4150 L,3368,3/4,DVB-S2,ACM-I found also this transponder with GS
    Changing frequencies:
    3636 R 605 DVB-S2 MIS 1
    3638 R 1210 DVB-S2 MIS 1
    4195 L 5615
    Changing SR:
    4038 L 1480 DVB-S2
  • Zitat
    3636 R-Locked MIS 63
    Changing SR:
    4038 L 1480 DVB-S2
    Changing SR again:
    4039 L 2355 DVB-S2
    Changing SR again:
    4039 L 2355 DVB-S2
    Small SR changes:
    4039 L 2307 DVB-S2
    Original von superdish66
    3636 R 605
    3637 R 1210
    Not new, but NO LOCK by my side ATM
    Scan on this frequncy range.
    Some changes here.
    New:
    3688 L 4000 DVB-S2
    Left: 4039 L, 4195 L
    New:
    3882 L 1480 DVB-S2
    Just my scan.
    Can´t lock 3654 R 1210...
    Left: 3636 R, 3638 R and 3688 L.
  • Új beolvasási omicom.
    Helyszín: Nádudvar, magyar.
    2.4.x2.7.m Laminas.
    2,2 méteres fókusz.
    C, Ku sáv 95.0Kelet-55.5West.
