3655 R 605 looks like a MIS stream... ?
40.5°W SES-6
Not new
4150 L4038 L 1370 is also on air
3655 R 605 looks like a MIS stream... ?Same here...
3655 R 605 looks like a MIS stream... ?Hi Feedsat,
this evening I found something out...
CrazyScan has problems to lock sometimes MIS streams, even if the signal is pretty enaugh... This is not new, I know.
My trick:
1. Go first on a lockable carrier and lock it by opening "Constellation monitoring".
2. Than let "Constellation monitoring" opened and put the "NO LOCKED" data in: Frequency, Polarization, SR.
3. Click in "Blind Scan" field, as you do when you do a "hard lock" (look at attached file).
4. This is the important step! Than click "Update modulation info" (look attached file).
5. Now all is done and you can click to try to lock this frequency.
6. Good luck!
For me, it works on that carrier! Now I had to test some more of them...
... and a second carrier behind that ^^^
3657 R 1210 DVB-S2 MIS 1
PS: I don´t need a trick here.
Nice trick !
I will have a look later
4150 L,3368,3/4,DVB-S2,ACM-I found also this transponder with GS
Changing frequencies:
3636 R 605 DVB-S2 MIS 1
3638 R 1210 DVB-S2 MIS 1
4195 L 5615
Changing SR:
4038 L 1480 DVB-S2
Changing frequencies:3636 R 605 DVB-S2 MIS 1
3636 R-Locked MIS 63
Changing SR:4038 L 1480 DVB-S2
Changing SR again:
4039 L 2355 DVB-S2
3636 R 605
3637 R 1210
Not new, but NO LOCK by my side ATM -
Changing SR again:
4039 L 2355 DVB-S2
Small SR changes:
4039 L 2307 DVB-S2
ZitatOriginal von superdish66
3636 R 605
3637 R 1210
Not new, but NO LOCK by my side ATMScan on this frequncy range.
Some changes here.
New:
3688 L 4000 DVB-S2
Left: 4039 L, 4195 L
New:
3882 L 1480 DVB-S2
Probably moved from 3636 R
3653 R 605 - New, I think3654 R 1210 - Not possible ATM
3654 R 1210 - Not possible ATMNow Locked. It needs 12,0dB
Just my scan.
Can´t lock 3654 R 1210...
Left: 3636 R, 3638 R and 3688 L.
