30.9°E Türksat 5A
  • :51:
    These are the first signals in my country to appear from Türksat 5A:
    1=11586,V,2799,34,8PSK- LBC Internationa, 11.4dB
    2=11588,V,1299,56,8PSK- LBCI AM, 12.2 dB
    3=11597,V,2499,56,8PSK- 6.6 dB no lock
    Borovo Naselje Croatia
    Starting a new toppic, thanks milan58. :76:
    These ones are not lockable from here. :79:
  • I adjusted the antenna a little better and the signal intensified:
    1=11586,V,2799,34,8PSK- LBC Internationa, 12.7 dB
    2=11588,V,1299,56,8PSK- LBCI AM, 14.7 dB
    3=11597,V,2499,56,8PSK- LEBANON 9.7 dB
  • Thanks milan58 :3:Signal very strong in my area on these first transponders activated on Turksat 5.
  • They've turned on this frequency, it can be locked but the signal varies a lot.
    11583,V,2142,34,QPSK- CH2 SD, 4.4dB
  • I've checked the signal now.It's stable,even stronger.
    A deeper look on these frequencies - already discussed in satellites.co.uk board earlier - it looks, according same content and paramter, like a "signal reflection" (+500MHz) from Arabsat 6A.
  • Turns out I was wrong about Turksat 5A. Transponders found appear to be on Arabsat 6A.
    I'm sorry I was wrong,but I'm glad Arabsat 6A is coming in in my area,But I don't know how long it will last.
  • Thanks milan58, I've got them on the spectrum too,with one extra:11594 V,11666,3/4,8PSK-NBN
  • Or Uplink (14.140 GHz) for Arabsat 6A after activated same Uplink on Turksat 5A.
  • The first frequency in horizontal polarization. Most likely this is a feed.
    11619,H,3332,56,8PSK- First_service 12.2dB
  • Now the promo frequency is active
    11159,H,3332,23,8PSK
  • 11504 H,12500,2/3,8PSK-Turksat Tanitim,too
    11158 H,3332,2/3,8PSK-Turksat promo :3:
  • whats about this satellite? no (positiv) report from anyone user in middle europe; i suppose we have the same condition like turksat beam; no success with 150 cm dish on my place.
    regards
    1 Gib. 150
    1 T90
    1 Gib. 125
    Signal check at 9.30 a.m. ~1.0dB more needed for 11158 H 3333 2/3 DVB-S2 8PSK at this time on 2.2m. Nothing from 11504 H at my place.
  • Here's the signal at 30.8E in my area atm,the first one with a 1.50m antenna and the other one with 1.10m.
  • there are 2,8dB penetrating, but not continuous; but where from comes this signal, 30,5 ?
    1 Gib. 150
    1 T90
    1 Gib. 125
