3 unlocked frequencies in 8PSK 5/6, all with -10db, constellation looks OK.
Probably feeds, thanks to Enosat for PLS of 12697V.
All 3 TPs on now, with PLS , first two test card, third with transmission.
Same PLS.
3 feeds on ,with same PLS.
12704 V 2500 5/6 8PSK PLS
12707 V 2500 5/6 8PSK PLS
12698V and 12707 V 2500 5/6 8PSK PLS
Tandberg and Antena 3 feeds.
11055 V 2200 7/8
signal is weak and SNR always changing
(also a feed on 12562 V 3820 3/4 fyi)
Antena 3 feed 12703 V 2500 5/6 8PSK PLS
Scopus Network Technologies
ROU-037
12572 V 2222 - 3/4
/edit by qwer: Merged in Feeds>Ku.
Two weaker feeds .
12556 V 3818 3/4 8PSK
12561 V 3818 3/4 8PSK
12572 V 2222 - 3/4 active now again with Black scream
PMT PID: 4217, SID: 1 @ ROU-036 (Scopus Network Technologies)
edit ; is active now !
12513 V,2500,5/6,Dvb-S2/8PSK,code:113344-Rou 25,
12647 V,2500,5/6,Dvb-S2/8PSK,code:113344-Rou 25:
12507 V 2500 5/6 8PSK PLS, Tandberg TV
12513 V 2500 5/6 8PSK PLS, Antenna 3
Same content on:
12641 V 2500 5/6 8PSK PLS and
12647 V 2500 5/6 8PSK PLS
10981 V 9600 3/4 New place for Italian Footy Feeds Serie A
Now:
12505 V 2500 5/6 8PSK PLS,
12511 V 2500 5/6 8PSK PLS,
12517 V 2222 3/4 DVBS
I have observed an intersting uplink problem at 33°E, not my reception, it happens only on the upper low band in H, a weak signal is a "copy" of the upper band
now 11697 V 2222 3/4 is the feed of 12517 V 2222 3/4
11697 H, the signal is very weak but active, this is not the first time I see it but never reported before.
have you ever notice this 2 ?
11697 & 12517 H, same L band freq....
Interesting,
I can "lock" 11697H but no content. Maybe later.
Again 12508 V,2500,5/6,8PSK-DSNG 6 RO 26(Antena 3)
