Es war schon immer so.
Deshalb zeigen wir den pfad
für andere Programme wie VLC, Transedit, ABC4T2.
This has always been the case.
That's why we show the path
for other programs like VLC, Transedit, ABC4T2.
for other programs such as VLC, Transedit, ABC4T2.
Yes okay ,
but what do I need to do to execute that correct path so that the program works.
In other words :
don't beat around the bush (to the point plaese)
Ich glaube, Sie müssen jemanden fragen, den Sie kennen.
Er konnte für Sie es tun und den richtigen Pfad in das Programm eingeben.
Von Anfang an haben Ihnen mehrere Personen im Forum gezeigt
mit Bilder wie man das tut (unter anderem Qwer)
und leider verstehen Sie nicht, wie man das macht.
Es wäre wirklich die beste und wahrscheinlich die richtge Lösung,
denn wie Sie sagen, drehen wir uns im Kreis.
I think you need to ask someone you know.
He could do it for you and enter the right path into the programme.
From the beginning, several people on the forum have shown you
with pictures how to do it (Qwer among others).
and unfortunately you don't understand how to do it.
It really would be the best and probably the right solution,
because, as you say, we're going in circles.
Good luck
Is there a video there of how to install IQMonitor.
There are a lot of pictures on the Forum what members can receive, but that does not help this young person.
You have now shown me a video, how it works, absolutely top.
regards
I think DVBViewer has adopted Transedit 4.2.1.1.
When I extract TransEdit zip I see a completely different TransEdit.exe.
How do I change that !!
Regards
yes okay ,
In other words :
If you have not installed TS Reader light: install the program
If you use IQMonitor 2407 edit the IQMonitor_2.ini
If you are using IQMonitor_Pro edit the IQMonitor_Pro.ini
In the [PARSER] Section of this files you have to write or insert the path of the other programs
for example:
[PARSER]
TSRLite=C:/Program Files (x86)/Cool.stf/TSReaderLite/TSReaderLite.exe
TSR=C:/Program Files (x86)/Cool.stf/TSReader/TSReader.exe
VLC=C:/Program Files/VideoLAN/VLC/vlc.exe
... the same problem with Transedit
What does code mean :
I/O error 103
in IQMonitor Pro
What did you do?
I / O errors can have different causes.
I don't know .
I'm trying everything to get a picture.
where I have saved IQMonitor I will first check with TransEdit on which transponder on 7 degrees East I have image.
Then I switch on IQMonitor and start scanning.
I look for the relevant.
then (tune to tuning), he has a (lock) and starts streaming to udp 2103
VLC comes up but nothing happens,no picture.
Not on MPC-BE /TSreader Lite. etc etc
Try it on 7°E with 11262 H 27500 2/3, there should be all free to air channels.
If you have not a picture, post or attach (as zip) your IQMonitor.ini.
Destroy TransEdit from your brain, you dont need it first time!
your IQMonitor.ini. !?
What do you mean by this?
Can you show what you mean!
regards.
No, I cannot show. I would see your entries in the ini-file.
Huh ,entries ini-file ?!
I believe I have it.
Saw my first image tonight.
regards
Hello members ,
a question, how did you fine-tuned the lnb and the rest, so not the motor on which the dish runs.
Best regards
Huh: Code ?!
/edit by qwer.
You actually only need to enter the LNB used, e.g. Universal for the Ku-band or whichever is used.
As an inexperienced person, I would strongly advise against any other recruitment attempts.
huh?!
that's not what i mean.
how did you optimize the dish to receive the signals.
guess you did that
Best regards
/edit by qwer.
I downloaded the IQmonito Pro version, unpacked files, transferred v1013 to the base folder and opened up the program.
None of the interface buttons or drop downs are working. it opens the interface then all is frozen?
same to me. 1st put Programm-start-icon to your quick launch bar.Then start it.
Use your alt-Tab on your keyboard when you see interface .
then klick on Programm-icon on your IQ-M on quick launch bar. Programm disappear in Background. Then do it after 5secs twice time .
then appears .Good Luck!
guess you did that
Start program, select a satellite, select transponder, press "Dynamical".
If you turn your dish now, higher values are better optimized
