07.0°E Eutelsat 7B/7C
  • Da Satesco so viele S2X- Transponder gefunden hat,die nicht sind weil ich sie vorher gefunden habe mit nicht S2X-Receiver z.b. TBS 5990 kann sich hier beweisen ob das ein S2x-TP ist oder nicht .Ich meine ja weil mein TBS5990 die überhauptnicht erkennt,obwohl der mindestens 9,5dB hat (SF8008 angeschlossen mit gleicher Peripherie)
    Viel Glück .Sender wird wohl bis heute Abend da sein bis er dann abgeschaltet wird.
    dvbsnoop V1.4.56 -- https://github.com/OpenVisionE2/dvbsnoop
    Transponder PID-Scan...
    PID found: 0 (0x0000) [SECTION: Program Association Table (PAT)]
    PID found: 1 (0x0001) [unknown]
    PID found: 2 (0x0002) [unknown]
    PID found: 3 (0x0003) [unknown]
    PID found: 4 (0x0004) [unknown]
    PID found: 8 (0x0008) [unknown]
    PID found: 9 (0x0009) [unknown]
    PID found: 10 (0x000a) [unknown]
    PID found: 14 (0x000e) [unknown]
    PID found: 16 (0x0010) [unknown]
    PID found: 17 (0x0011) [unknown]
    PID found: 18 (0x0012) [unknown]
    PID found: 19 (0x0013) [unknown]
    PID found: 20 (0x0014) [unknown]
    PID found: 22 (0x0016) [unknown]
    PID found: 26 (0x001a) [unknown]
    PID found: 28 (0x001c) [unknown]
    PID found: 32 (0x0020) [unknown]
    PID found: 33 (0x0021) [unknown]
    PID found: 36 (0x0024) [unknown]
    PID found: 256 (0x0100) [SECTION: Program Map Table (PMT)]
    PID found: 512 (0x0200) [PS/PES: ITU-T Rec. H.262 | ISO/IEC 13818-2 or ISO/IEC 11172-2 video stream]
    PID found: 768 (0x0300) [unknown]
    PID found: 4112 (0x1010) [PS/PES: ISO/IEC 13818-3 or ISO/IEC 11172-3 audio stream]
    PID found: 4113 (0x1011) [PS/PES: ISO/IEC 13818-3 or ISO/IEC 11172-3 audio stream]
    PID found: 4114 (0x1012) [PS/PES: private_stream_1]
    PID found: 8191 (0x1fff) [stuffing]
    root@sf8008twin:~#
    General
    Complete name : D:\!FTA\20210916 1414 - 10983V SID 0x01 - instant record.ts
    Format : MPEG-TS
    File size : 74.5 MiB
    Duration : 21 s 481 ms
    Overall bit rate mode : Variable
    Overall bit rate : 28.8 Mb/s
    Video
    Menu ID : 1 (0x1)
    Format : HEVC
    Format/Info : High Efficiency Video Coding
    Format profile : @L5.1@Main
    Codec ID : 36
    Duration : 21 s 500 ms
    Bit rate : 24.3 Mb/s
    Width : 3 840 pixels
    Height : 2 160 pixels
    Display aspect ratio : 16:9
    Frame rate : 50.000 FPS
    Standard : Component
    Color space : YUV
    Chroma subsampling : 4:2:2 (Type 2)
    Bit depth : 10 bits
    Bits/(Pixel*Frame) : 0.059
    Stream size : 62.2 MiB (83%)
    Color range : Limited
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Audio #1
    Menu ID : 1 (0x1)
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 2
    Codec ID : 3
    Duration : 21 s 480 ms
    Bit rate mode : Constant
    Bit rate : 384 kb/s
    Channel(s) : 2 channels
    Sampling rate : 48.0 kHz
    Compression mode : Lossy
    Delay relative to video : -930 ms
    Stream size : 1 007 KiB (1%)
    Audio #2
    Menu ID : 1 (0x1)
    Format : MPEG Audio
    Codec ID : 3
    Bit rate : 384 kb/s
    Audio #3
    ID : 4114 (0x1012)-1
    Menu ID : 1 (0x1)
    Format : Dolby E
    Mode : 20
    Format settings, Endianness : Little
    Muxing mode : SMPTE ST 302 / SMPTE ST 337
    Codec ID : 6
    Duration : 21 s 440 ms
    Encoded bit rate : 2 304 kb/s
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Frame rate : 25.000 FPS (1920 SPF)
    Bit depth : 20 bits
    Delay relative to video : -970 ms
    Audio #4
    ID : 4114 (0x1012)-2
    Menu ID : 1 (0x1)
    Format : Dolby E
    Mode : 20
    Codec ID : 6
    Encoded bit rate : 0 b/s
    Channel positions : Front: L R
    Bit depth : 20 bits
  • 7.0E_10983 V,17141,23/36,(S2X)/16APSK,HEVC-Service feed(locked with 6902se card)
    With any card with S2X extension it locked!I used tbs6902se card for this feed. AltDVB runs this S2X feed excellently.
    Thanks ZAZA :3:
  • Das war dann auch der S2X-Beweiss dafür das viele angebliche S2X-Tps die von Satesco auf FS geposted sind ,garkeine sind ,revidiere dann hiermit die gefundenen Daten-TPs von Satesco auf FS. Er kann sie dann herabstufen auf S2-Normal.Programs are not Perfect Satesco.THX 4 understanding
    Great h265 4K 4:2:2 feed - friends, you can test powerful of your processors while playing my records from that feed
    20210917-000626_(noname) SID 1.ts (452 MB, 1min39s) https://transfiles.ru/63cn9
    20210917-003653_(noname) SID 1.ts (1.6 GB, 6min) https://transfiles.ru/34i62
    20210917-004653_(noname) SID 1.ts (12МБ, 1min40s) https://transfiles.ru/ml2tq
    "That was then also the S2X proof for the fact that many alleged S2X-Tps of Satesco on FS are posted, are none, revise then hereby the found data-TPs of Satesco on FS. He can then downgrade them to S2-Normal.Programs are not Perfect Satesco.THX 4 understanding"
    I hope I don't misunderstand the above quote translated by google, by which my forum colleague questions that the S2X extension parameters I report on FS are, as they say today, in other words, "fake news, by so you called, "alleged S2X Tps..."
    Once again I say, I don't understand what you mean ZAZA by making such a statement. So that what I post here or elsewhere is false information?
    I have to remind you that transponders using S2X extension have also modes in dvb-S2,it depends on several factors, first of all on the physical support of the device used, in our case dvb cards, some more powerful,some less, it depends on the demodulator, and on the other hand on the strength of the received signal. The weaker a signal is the more difficult it is to lock.
    Another thing to know is that TV programs and feeds in S2X, like the one from 7.0E and others, usually transmit with the same parameters (extension, mode, fec, roloff, etc.), while Data transponders use several modes at the same time, even more so when they have multistreams. That's why you will find the same transponders with S2x extension parameters as with DVb-S2.
    I won't go into details, but the above observations are the result of my experience as a simple user,and not a specialist of these cards.And if I write from time to time about these cards, I do it from the perspective of a regular user, trying to highlight what one card or another can and cannot do.
    We also have to take into account the fact that the dvb applications we use are not perfect either, which is why their developers ensure a continuous update, those who do this, which in some cases some results could be doubtful, especially in the case of new cards with the latest technology. Only such a programmer could tell us how much work is needed for his application to be as perfect as possible. That's why I don't even develop this idea.
    And let's not forget another thing, we, the users of these applications need to understand how the application/utility works in order to be able to exploit it at the level the developer thought.
    To which I add the fact that we need to know what the card can do, if it is able to highlight the information we receive when scanning a transponder. Or we know that, although cards with S2X extension can do the same thing in theory, in practice the result is different from one card to another.
    I won't elaborate on the idea, because I don't want to tire out the readers of this answer, but I assure you that what I post here or elsewhere can be verified by anyone.
    As for the information on FlySat, I try to send reports only after I have verified the information, but I must add that much of the information posted there is outdated, because the contributors have not returned after it is no longer relevant. I have also noticed that some contributors who do not receive a transponder, for example with a weak signal, or who do not have the right device, report wrongly that they are not active. This is the case with transponders with low symbol rate, which some of them say does not exist. And then, it is understandable why some information on FlySat seems to some to be wrong.
    My intervention now is only because of that "alleged",which simply intrigues me, which I find discrediting.
    If somehow I misunderstood your message, I have nothing more to add and I apologize.
    Regards
  • Da muss man wirklich nicht so viel schreiben.
    Es geht nur um die S2X-TPs .ich habe mehrere S2-Tps bei FS geposted .einige Zeit später wurde nachträglich von ihnen gepostet ,das es S2X-TPS seien .Stimmt aber nicht weil meine Satcard gar nicht erfassen kann. Genauso wie der Feed gestern. Konnte nicht erfassen .Nur mein SF8008 mit bis zu 12dB. Also kann gar nicht sein das einige auf 33E und 13E ... gar nicht S2X sind.
    ganz einfache Schlussfolge. Dies habe ich mehrmals überprüft und deshalb auch andere angeschrieben. Alle sagten es ist S2X-TP auf 7°E
    und deshalb fand meine TBS5990 auch absolut gar nix.
    Und mein SF8008 zeigt nicht xtra an das es ein S2X-TP ist.
    Auf 33E
    Eutelsat 33B-Intelsat 28 33.0E 0330 TBS 5990 DVBS/S2 Tuner A 11241 Vertikal 31430 16APSK 2/3 DVB-S2 ON 0.35 Normal ACM 83.193 42.429 10,4 -41 MIS: 1, BER: 0,000000, Time to Lock: - ms 26.05.2021 23 01
    Eutelsat 33B-Intelsat 28 33.0E 0330 TBS 5990 DVBS/S2 Tuner A 11257 Horizontal 31429.686 16APSK 2/3 DVB-S2 ON 0.20 Normal ACM 83.193 37.714 3,0 -43 MIS: 1, BER: 0,000000, Zeit bis sperren: - ms 13.09.2021 2122
    Eutelsat 33B-Intelsat 28 33.0E 0330 TBS 5990 DVBS/S2 Tuner A 11279 Vertikal 31429.708 16APSK 3/4 DVB-S2 ON 0.20 Normal ACM 93.658 37.714 9,5 -48 MIS: 1, BER: 0,0000000, Time to sperren: - ms 25.08.2021 1948
    Eutelsat 33B-Intelsat 28 33.0E 0330 TBS 5990 DVBS/S2 Tuner A 11297 Horizontal 31429.664 16APSK 5/6 DVB-S2 EIN Auto Normal ACM 104.030 42.429 12,5 -43 MIS: 1, BER: 0,000000, Zeit bis sperren: - ms 26.05.2021 2301
    Eutelsat 33B-Intelsat 28 33.0E 0330 TBS 5990 DVBS/S2 Tuner A 11335 Horizontal 31429.708 16APSK 2/3 DVB-S2 EIN Auto Normal ACM 83.193 42.429 0,0 -45 MIS: 1, BER: 0,000000, Zeit bis sperren: - ms 23.08.2021 11:23:35
    Eutelsat 33B-Intelsat 28 33.0E 0330 TBS 5990 DVBS/S2 Tuner A 11354 Vertikal 31429.686 32APSK 3/4 DVB-S2 ON 0.20 Normal ACM 116.916 37.714 10,4 -47 MIS: 1, BER: 0,0000000, Zeit bis sperren: - ms 13.09.2021 11:09:59
    Eutelsat 33B-Intelsat 28 33.0E 0330 TBS 5990 DVBS/S2 Tuner A 11373 Horizontal 31429.664 16APSK 5/6 DVB-S2 ON 0.20 Normal ACM 104.030 37.714 9,5 -43 MIS: 1, BER: 0.0000000 26.05.2021 2201
    Eutelsat 33B-Intelsat 28 33.0E 0330 TBS 5990 DVBS/S2 Tuner A 11450 Horizontal 31430 Auto Auto DVB-S2 OFF Auto Normal ACM 0,000 42.429 9,0 -48 MIS: 1, BER: 0,000000, Sperrzeit: - ms 04.10.2020 1935
    Eutelsat 33B-Intelsat 28 33.0E 0330 TBS 5990 DVBS/S2 Tuner A 11489 Horizontal 31429.708 8PSK 2/3 DVB-S2 OFF 0.35 Normal ACM 62.261 42.429 0,0 -47 MIS: 1, BER: 0,000000, Zeit bis Sperre: - ms 04.10.2020 1900
  • Q.E.D. :26.
  • Q.E.D. :26.
    33.1E_11200-11700 HV scanned with tbs6983,6903x,tbs6902se cards.
    (Sorry about offtopic)
  • keine Ahnung ,was du wieder gegenbeweisen willst.
    All deine Hoffnungen setzen im voraus
    1. Crazyscan hat 1000% recht.
    2. Deine Sat-Grösse hat 1000% recht.
    deine Bilder kann ich im meinen SAT-TBS5990 zeigen.
    muss ich aber nicht. Dir gehts wahrscheinlich um was ganz anders??
    deine Meinung ist ganz schlichtweg für die Tonne.
    Jeder soll sein möglich grösstes seitens Sichtung und Auswertung erreichen.
    Das ist die Definition meinerseits und die sollte für alle gelten!DXX-4ALL
    Hör auf damit!
  • @ZAZA
    As I understand satesco with his screenshots wanted to say that ACM(VCM) (not CCM) DVB-S2X signal can be locked with DVB-S2 devices because such transponders transmits as minimum with two different parameters from frame to frame depending on conditions in place of receiving that transponder so almost simultaneously (if I remember correctly IQMonitor can show them clearly in Feed Report i.e. https://sat-dx.club/viewtopic.php?p=27866#p27866 ) and CrazyScan shows different parameters from one scan to another (because parameters can be changed at any time) on ACM(VCM) transponders depending what frame is locked...
    Einmal editiert, zuletzt von VictorLS ()
  • (because parameters permanently are being changed) on ACM(VCM) transponders depending what frame is locked...
    this is the 1st think !
    believe to another ??
    I have never time say its a S2X-Signal.
    No way!
    Only my 2xOctagon S2X can say there is a Signal, but cannot say Signal for S2X-Signal no way out!
    ZAZA,
    mit dieser Aussage überschreitest du hier die Etikette im Forum. Es sollte hier mehr um ein Miteinander und nicht Gegeneinander gehen. Bitte denke in Zukunft daran.
  • 7E 10984 H 16951 S2X 4:2:2 FTA 4K UHD FTA
    Video: HEVC 3840x2160 50fps [V: hevc rext, yuv422p10le, 3840x2160]
    Audio: MPEG Audio 48000Hz stereo 384kbps [A: mp2, 48000 Hz, stereo, 384 kb/s]
    Audio: 0xffff 48000Hz stereo 2305kbps [A: s302m, 48000 Hz, stereo, s20, 2305 kb/s]
  • Der S2x-taugliche GTMedia V8 Satfinder kommt offensichtlich mit dem 16APSK nicht zurecht :88:
