tbs6904SE
  • TBS6904se--DriverVer- 1.0.0.4 04/30/2023,
    Debug builds 6904SE drivers (self-signed)
    Fixed SNR in extended statistic (more precision)
    Fixed BER in extended statistic
    Removed modcode extension
    Auto TS clock setup
  • satesco,
    muss der vorhandene Treiber vorher deinstalliert oder entfernt werden? Ich hatte versucht per Gerätemanager die TBS6904SE-debug 1.0.0.3 über den originalen Treiber zu installieren und es hat mir meine Karte abgeschossen. So das ich wieder zurück zum originalen musste.
    the existing driver must be uninstalled or removed before? I tried to install the TBS6904SE-debug 1.0.0.3 over the original driver via device manager and it shot my card down. So I had to go back to the original.
  • satesco,
    As you know, I don't have the 6904se card, so I don't know why you have problems installing a new version. Maybe femi can help you.
    I don't have any problems installing new drivers on 6902se.
  • Im Normalfall updatet man nur, ohne vorher großartige Deinstallation zu machen. Bei mir klappte das nicht ... es kam ein Fehlercode.
    Probiere ich eventuell später noch mal.
    Normally, you just update without doing a great uninstall first. This did not work for me ... it came an error code.
    I may try again later.
  • tbs6904SE driver 1.0.0.4(4/30/2023) with old m88rs6060 firmware 30
  • Hallo Satesco,
    danke für deine Infos hier, aber gibt es keine Readme dazu? Oder eine Originalquelle, was das Update bringt oder behoben hat? Im Normalfall wechsle ich ansonsten nicht alle paar Wochen die Treiber.
    Grüße
    Hello Satesco,
    thanks for your info here, but is there no readme on this? Or an original source on what the update brings or fixed? Normally I do not otherwise change drivers every few weeks.
    Greetings
  • The latest StreamReader files and drivers are intended to optimize and remove streaming issues for those using the 6904se/6902se cards of the MSG (EumetCast) group.
    And yes, they may not be necessary for other users. But, as we know, since the chip m88rs6060 cards is not fully finished for these cards any tests and improvements made by CrazyCat are welcome. And it's good to know that.
