14.0°W Express-AM8
Alles anzeigen
Yes everyone was picked up from the morning
But I only got a stream code for this frequency
Therefore, the rest of the frequencies have not been published
Code
Alles anzeigen<!-- File created on Saturday, 26 of February 2022, 05:18:23 using sf8008t receiver running Enigma2 image, version 5.0, build 008, with the blindscan plugin Search parameters: Tuner A: Si2166D (DVB-S2X) Satellite: 14.0W Ku-band Express AM8 Start frequency: 10700MHz Stop frequency: 12750MHz Polarization: vertical and horizontal Lower symbol rate: 1000 Upper symbol rate: 45000 Only save unknown tranponders: no Filter out adjacent satellites: up to 3 degrees Scan duration: 380 seconds --> <satellites> <sat name="14.0W Ku-band Express AM8" flags="0" position="3460"> <transponder frequency="10955000" symbol_rate="1555000" polarization="0" fec_inner="3" system="0" modulation="1" /> <transponder frequency="10958000" symbol_rate="1000000" polarization="0" fec_inner="0" system="0" modulation="1" /> <transponder frequency="10974000" symbol_rate="2963000" polarization="0" fec_inner="3" system="0" modulation="1" /> <transponder frequency="11101000" symbol_rate="4162000" polarization="0" fec_inner="2" system="1" modulation="4" /> <transponder frequency="11121000" symbol_rate="3590000" polarization="0" fec_inner="3" system="1" modulation="2" /> <transponder frequency="11456000" symbol_rate="3000000" polarization="0" fec_inner="3" system="0" modulation="1" /> <transponder frequency="11563000" symbol_rate="14586000" polarization="1" fec_inner="3" system="1" modulation="2" /> <transponder frequency="11633000" symbol_rate="14182000" polarization="1" fec_inner="3" system="1" modulation="2" /> <transponder frequency="11650000" symbol_rate="14183000" polarization="1" fec_inner="3" system="1" modulation="2" /> <transponder frequency="11652000" symbol_rate="6000000" polarization="0" fec_inner="3" system="1" modulation="2" /> </sat> </satellites>
next for test tr.D6
11544V DVBS2 8PSK 14180 3/4
11564V DVBS2 8PSK 14585 3/4 -
Hi,
are they still all active??
i only see :11646 V,14182,3/4
dish needed a fine tune ..all 3 transponders ok now !
It was not the fault of the antenna tuning, the transponders were temporarily turned off :)
Transponder Pojedynczy 10972 H 1500 jest
Stabilna recepcja Antena 180cm Skandynavia (koło Malmó)
Etihad TV IBN
looks like the russians T2MI services in this Satellite left ..
