42.0°E Türksat 5B
    Just my signal with 2.2m on:
    11345 H 30000 3/4 DVB-S2 8PSK
    ...and next:
    11385 H
    ...here we go:
    11385 H 30000 3/4 DVB-S2 8PSK
    ...and next:
    11425H
    ...here we go:
    11425 H 30000 3/4 DVB-S2 8PSK
  • 10722 H-test carrier
    Not lockable under 3/4 8PSK... as you can see :26. - but now in 5/6 DVB-S: You´re try again hvdh!
  • You are right, hvdh :3:, both transponders are active but the signal is weaker than between 11200-11450 V.
    It's probably on another beam?
    Thanks satesco , my guess it's Turkey beam since the dB's are not great even at your location!
    qwer, DVB-S 5/6 also showed up here in the scan, but no lock as expected.
    Edit: next pair is up with DVB-S 5/6 30000: 10806H and 10844H.
    Next ones...
    10806 H and 10844 H
    ...here we go:
    10806 H 30000 5/6 DVB-S
    10844 H 30000 5/6 DVB-S - very weak signal here
  • I am posting Turksat(3A,4A,5B) reception for those interested in receiving it with a smaller antenna. Mine is 1.10m and a 6903 card.
    I hope it is not offtopic the Turkast spectrum as they are doing tests on 5B. If the moderator thinks it's not worth keeping, then no offense.)
    I think we're dealing with 72 MHz transponders, hence testing doubles:
    Nr.1 centered 10743H, testing with 10724H and 10762H
    Nr.2 centered 10825H, testing with 10806H and 10844H
    Nr.3 centered 10907H, testing with 10888H and 10926H (wait for it)!
    "Full power" - on only one:
  • Thanks, ocean :3:
    110805 H-this time the signal is stronger but also fluctuating.
    Here we go!
    ...and than they appeared:
    10888 H 30000 5/6 DVB-S
    10926 H 30000 5/6 DVB-S - weak signal again
    And now in vertical...
    10724 V and 10762 V
    ...and:
    10724 V 30000 5/6 DVB-S
    10762 V 30000 5/6 DVB-S
    Following next:
    10806 V and 10844 V
    Here they are:
    10806 V 30000 5/6 DVB-S
    10844 V 30000 5/6 DVB-S
    FYI: I attached my strongest signal (editing )
    Last ones:
    10888 V and 10926 V
    10888 V 30000 5/6 DVB-S
    10926 V 30000 5/6 DVB-S
