42.0°E Türksat 5B
  • 10704 H beacon
    I´m waiting... nothing in extenden Ku band range at this time (1,2m).
    I could not see anything on 10704H. There don't seem to be any beacons on nearby satellites in that region of sky so maybe it was a test.
    The beacons on 11452.6 & 11704.5 now have circular polarisation (they were linear a few months ago).
    The plots below show 11704.5C with:
    11699.5H Turksat 3A
    11698.5V Turksat 3A
    11701.5V Turksat 4A
    The LNB is about 70kHz high in frequency
    <edit> Here is some information from soon after launch:
    42.0°E (destination) Türksat 5B
  • I have tried on 10704, but there I found nothing H and V.
    separatly 11699 V
    11700 H ist stronger than 11700V
    with IQM
    also alone 11702 V
    and both 11705, maybe circular
    11699.5H Turksat 3A
    11698.5V Turksat 3A
    11701.5V Turksat 4A
    ...and my poor CrazyScan monitorings (2,2m):
    11452.6 and 11704.5 on both linear polarities - confirming circular polarity
    11699.5 H
    11701.5 V
    11698.5 is in H on my side (sorry) :77:
    Hier sind die beiden Spektrum, die für Beacons charakteristisch sind
    alles mit der TBS6983 und IQMonitor pro 1020 bekommen
    bei mir ist es mehr 11699 als 11704
    Here are the two spectrums characteristic of beacons
    got everything with the TBS6983 and IQMonitor pro 1020
    for me it is more 11699 than 11704
    Das gleiche in untere Bereich
    Deutliche constellation bei 10829 V ( beacon ?)
    The same in the lower area
    Clear constellation on 10829 V ( beacon ?)
    /edit by qwer: merged in this toppic
  • Die ersten Tests auf dem neuen satelliten, den ganzen Tag über wurden einige tests aufgeschalten bzw wieder abgeschalten.
    Zuletzt war / ist 11385 H 30000 aktiv :76:
    Ich selber bin im Urlaub und kann nicht kontrollieren.
    Bereits getestete Parameter :
    11226 H 30000
    11305 H 30000
    11345 H 30000
    48.14*N, 9.2*E
    Baden Württemberg/Zollernalbkreis
    ... nothing to see from my place in the past two hours in this frequency range... not sure about vertical spectrum 11.200-11.250... :125:
    Tests started in vertical range... bad situation from my place with 2.2m :90:
    11265 V 30000 3/4 DVB-S2 8PSK - unlocked
    11305 V
    11305 V 30000 3/4 DVB-S2 8PSK - unlocked
    11345 V 30000 3/4 DVB-S2 8PSK - unlocked
  • 11265V, 11305V, 11345V 10-11db in western Finland with 3m (when active) I guess 11385V is next..
    3m 53E - 8W, 2.4m 68.5E - 47.5W
    Octagon SF8008, Edision OS MIO
    Western Finland (63N 22E)
    I haven´t checked last two hours... probably some others appeared? /edit: indeed 11385 V was next, reported on satellites.co.uk,,, :72:
    14.10 CET - now active on pretty strong signal at my place (2.2m):
    11225 V 30000 3/4 DVB-S2 8PSK
    15.30 CET - very low signal now on 11225 V
    11265 V
    Now on
    11266 V 30000 3/4 DVB-S2 8PSK
    Checked this one here too - earlier...
  • 11224 H,30000,3/4,8PSK-colorbar_good signal with 1.10 dish in my area.
  • 11343 H,30000,3/4,8PSK-colorbar,again
