Show Program problem
  • you wrote from 26°E, ... but it's not 26°E, its 28.2°E
    To insert a picture
    select a window, use <ALT><PRINT>, open paint, use >STRG><V>, save the picture on your pc
    use here "Hochladen", select your picture and insert it with "Vorschau einfügen" (also "Original einfügen" its possible.
  • I'll ask the crystal ball what's in the picture, you should read and do as advised.
  • Hope some body can help me with de 4T2 Content Analyser.
    Whot i try no signal or picture.
    EnoSat
    You are right, but you have a license.
    And if there is no license, then the analyzer can be launched only from the IQmonitor program and only through the transport stream file.
    Moreover, the demo mode of the analyzer is used, no changes were made to its code, and the analyzer's copyrights are not violated. This is its legitimate use (not for commercial purposes)
  • There ist nothing to set, see #43
