Signal of the day.
10992 V 27500 3/4 DVB-S
<Aljazeera package>
Signal of the day.
<Aljazeera package>
Scan of the day.
Screenshots...
11474V 27500 3/4
After some time is receivable again.
QuoteOriginal von marval450
11474V 27500 3/4
Thanks marval450, well done!
My bad scan from this position.
Todays scan.
Today, thanks to the cold weather, I can receive 11474 V 27500 3/4 SNRT Package from NWA Beam with only 135 cm with very small pixelation. At 11595 V 27500 3/4 is missing only 0,5 dB to see a picture.
Greetings
Great catch Fidu and thanks for your post!
Thanks too. Maybe I can catch some more Transponder from this Beam, will keep trying
It has to be two years I saw this TP here.
Interesting is that with 4,5db it is working,DRHD with stopping picture, SX6 clearly without pixelation.
Working only by late night...
11474 V-Usually in the evening is the best signal at this position in my area.Only this transponder I managed to lock it.
Well done guys!
Scan of the day.
As they say,further away you are from the spot the greater the merit if you lock the signal.You are in this position
11657 V 27500 2/3
Thanks Feedsat, got 11657 V too.
PS: Active feed on 11626 V.
EDIT: 11658 V gone right now...
QuoteOriginal von qwer
And on again...
11658 V Tunisia 1 & 2 on test
According to official sources, 4 Berbere TV channels are supposed to be on 11595 V 27500 since today (also @5°W for a while)
is someone can confirm it...
QuoteOriginal von Feedsat
Added only one.
NWA beam is pretty strong by night, 11475 V had 6 db.
OK, Thanks Marval for checking
Two TPs today , with very nice signal.
Cant get 11559V probably some local interference.
And there is FEC 5/6, no chance...
