07.3°W Eutelsat 7 West A <NWA>
  • An update on what I'm getting right now at 7.3W.
  • I can see all Transponders from 7°W ,7.3°W and 8°W at the same time
    But I Have to point my dish @ 8°W :83:
    ..7°W and 7.3°W are strong here :73:
    Just a scan from my place in range 11.44 to 11.70 GHz - using Inverto Single - no locked: 11657 V and 11679 H.
  • Just a scan from my place in range 11.44 to 11.70 GHz - using Inverto Single - no locked: 11657 V and 11679 H.
    Looks like faulty lnb, those TP are not much weaker than rest. Typical for this mark.:28:
    Kovosat 115cm, KaD band,
    DR HD F15,Octagon SF8008
    TBS 6983
    Okay thank you marval450!
    I will have a try (when there is more time) with my usual Invacom flange next time (and I can confirm what you wrote, checking my resuls in earlier scans on those TP)...
    Best regards
    qwer.
    Gerade die beiden würden hier funktionieren, im Vergleich relativ gut :26:
    Dafür fehlt anderer Stelle jede Menge :28:
    Einmal editiert, zuletzt von Isotrop ()
    Just another look on this beam.
    Night scan from this beam at my place. 10992 V is not lockable.
  • Night scan,in my area at 00.30 am,the best reception time of Nilesat & Eut 7W for most of Europe.I recommend for those with small antennas the IQmonitor application.
  • New scan omicom.
    Helyszín: Nádudvar, magyar.
    2.4.x2.7.m Laminas.
    2,2 méteres fókusz.
    C, Ku sáv 95.0Kelet-55.5West.
    Just another try... still same: 10992 V is not possible, +1.0dB more needed - other 6 frequencies from NWA beam okay at this time.
  • New on FS: 11078 V DVB-S2 5000 3/4 , reality:
    11078 V 5000 3/4 8PSK 9/10
    this TP is weaker, no lock here.:28:
    TBS 6983
    I can confirm... :79:
  • Data transponder.
    -Winegard Mesh 3.10m
    -Famaval 1.80m
    -Gibertini 1.25m
    -TBS6903 - TBS6902 - TBS6922TE - TBS5520SE
    -MediaKind RX8200
    -58ºW <>53ºE
    -KU + KA + C
    -Loc: Spain
    Almost there.:51:
    TBS 6983
    11075 V 5000 9/10 is far a way from lock at my place - weakest signal from this position.
    ...but I can lock -in manual- and on the limit after a long time again: 11158 V 5000 9/10 - too bad signal for content.
  • Almost there.:51:
    Pretty nice signal appeared here. Looks like data.
    TBS 6983
  • Well, we can see now on FS , on this TP(11076) are OTT channels .
    Same packet is on 10720 V. PID 3002. (used Smartbeamextractor).
    TBS 6983
