my scan 20.03.2020
andrew 180 x 200 cm
my scan 20.03.2020
andrew 180 x 200 cm
An update on what I'm getting right now at 7.3W.
My scan.
I can see all Transponders from 7°W ,7.3°W and 8°W at the same time
But I Have to point my dish @ 8°W
..7°W and 7.3°W are strong here
Just a scan from my place in range 11.44 to 11.70 GHz - using Inverto Single - no locked: 11657 V and 11679 H.
Looks like faulty lnb, those TP are not much weaker than rest. Typical for this mark.
Okay thank you marval450!
I will have a try (when there is more time) with my usual Invacom flange next time (and I can confirm what you wrote, checking my resuls in earlier scans on those TP)...
Best regards
qwer.
Gerade die beiden würden hier funktionieren, im Vergleich relativ gut
Dafür fehlt anderer Stelle jede Menge
Just another look on this beam.
Night scan from this beam at my place. 10992 V is not lockable.
Just another try... still same: 10992 V is not possible, +1.0dB more needed - other 6 frequencies from NWA beam okay at this time.
11078 V 5000 3/4 8PSK 9/10
this TP is weaker, no lock here
I can confirm...
Alles anzeigenNew on FS: 11078 V DVB-S2 5000 3/4 , reality:
this TP is weaker, no lock here.
Data transponder.
Almost there.
