07.0°W Nilesat 301
  • This is my reception for 12053V. For 12303H I have no lock. From Rome, Italy, Laminas 120.
    Big thanks to Paolo71 and duck77 for your scans. :74: :73:
    Paolo71 as I can see, your signal on 12053 V is very strong now on 1.2m and about 5,5dB increased according your last summer scan.
    I´m quite sure now, according our reports here, that 12053 V is changed back to Nilesat 201.
    PS:
    :64: Probably Fidu and elchromo read our reports here too and they can confirm de-creased/unlockable signal on 12053 V?
  • Hi Qwer
    My Antenna will be back on Balcony only in September. I cant test earlier.
    Sorry
    Fidu
  • Okay, thanks Fidu. :74:
  • No changes here for me (2.2m)... only BS lock for 12303 H - not possible in manual scan since several month.
  • Now from my place. for BS see here
    12053 V
    12303 H - Lockable even in manual, but 0.0dB SNR
    RotorFeed: C LR/HV+KU H/V
    TBS5925-6983+6908
    RC2000C
  • Now,
    12303 H possible and stable
    TBS5925-6983+6908
    RC2000C
  • Hello
    My Antenna is again on Balcony installed now and I can confirm that only 12303 H is receivable. On 12054 V the Signal decreased by about 4 dB.
    Greetings
    Fidu
  • Big thanks Fidu and superdish66 for your reports about the two frequencies in your area. It´s exactly, what we thougt...
  • 1.8m not acurate set
    this position is more complicated than end user can expect....
    Tried again tonight...wow, I can lock 12303 H via "PLS trick" on TBS 6522 again in 2023 (4.8dB) :48:
  • New and unlocked here - already reported by G.Abdelhamid on FlySat 14.09.2023:
    11804 H 27500 3/4 DVB-S2 8PSK, Nilesat promo?
    Probably Fidu or superdish66 or someone else (of course) could have a look on this one: 11804 H 27500 3/4 DVB-S2 8PSK.
    In my last scan I have a very low signal on 11804 H in comparison to other S2 transponder from Nilesat 201. Probably this one is from Nilesat 301...
    PS: Reading some reports on satellites.co.uk from today... :72:
    11804 H with 3.5dB, my current signal, about 4.2dB under LM... :90:
  • I think its from Nilesat 301 because now I have about 3dB unlocked and before I had no Sign of a Signal at all on 11804 H
  • Thanks Fidu for confirming. :76:
    FYI: I´ve merged yesterdays two reports above about 11804 H 27500 3/4 DVB-S2 8PSK, Nilesat promo in this toppic now.
    In my current scan you can see the much lower S2-signal for 11804 H in comparison to the other S2-(unlocked)-signals from Nilesat 201 from my place on 2,2m.
    1,8m "Prodelin" + VonWeise 24" (85E-34,5W)
    1,8m "Prodelin" + Egis Profi Tracker (polarmount mode testing)
  • Big thanks Lambda for confirming 11804 H signal from Nilesat 301 at your place. :76:
    In the early and cold morning hours signal is a bit better on:
    11804 H 27500 3/4 DVB-S2 8PSK up to 4.3dB
    12303 H 27500 3/4 DVB-S only -10dB via BS (TBS 6903)/ 4.0dB via manual lock (PLS "trick"/TBS 6522)
  • 11805H
  • 12303 H 27500 3/4 DVB-S is always lockable from my place in the early morning hours (-10dB via BS on TBS 6903)
    But with 4.2dB via manual lock on TBS 6522, signal is 0.5dB too low for analyzing stream.
    PS: 11805 H is far away from lock...
    /edit: scan (TBS 6903)
    Current reception of 12303 H from NW Italy with my unstable setup
    TBS5925-6983+6908
    RC2000C
  • ...waiting for colder temperatures outside (but only for DXing....)
    Today manual lock via "PLS trick" on TBS 6903 too... but too low signal for video stream.
  • My reception of 12303 H from my office in Rome with a 3.7m. Today a bit cloudy.
