Galaxy 25 closed?
  • Why the Galaxy 25 topic at 66.1E is closed :25:
    Hi satesco,
    this toppic (and others there) are for creating the various lists that I update regularly through the forum messages in the forum toppics. These toppics are therefore closed, because otherwise posts would be placed across the lists, which would be very confusing.
    In these list sections, the toppics are closed:
    C-band feeds lists
    C-/Ku-band GSE lists
    X-band Index
    Ka-band lists
    I hope, I have answered your question.
    PS: The toppic for your recent post above belongs to GS>Ku section and you can find it here. :74:
    Best regards
    Dieses toppic (und andere dort) sind zum Erstellen der verschiedenen Listen, die ich regelmäßig durch die Forenmeldungen (hier: in den Forentoppics update. Diese toppics sind also geschlossen, weil sonst Beiträge quer in den Listen stünden, was sehr unübersichtlich wäre.
    In diesen Listen Sektionen sind die Toppics geschlossen:
    C-band feeds lists
    X-band Index
    Ka-band lists
    Ich hoffe, deine Frage beantwortet zu haben.
    PS: Das toppic zu deinem letzten Beitrag oben gehört zum GS>Ku Bereich und du kannst es hier finden.
    Schöne Grüße
    C-band: 55.5°West-68.5°East ORBITRON O-16 (4,9m) / X-band: 17.8°W-60.2°E KATHREIN CAS 120 (1,2m) / Ku-band: 61.0°West-80.0°East KATHREIN CAS 23 (2,2m)
    Ka-band A/B/C/D: 30.0°W-75.0°E KATHREIN CAS 018 (1,8m) / Ka-band band A 2x KATHREIN CAS 120 fix on 19.2°E and 42.0°E
    C-band LNBs: Kaonsat, C-Panorama 13K, Norsat 8000RI C-DRO, BrasilSat LNBF AP30 PLL / X-band LNB: Norsat X1000HAF / Ku-band LNB: Invacom SNF-031, Inverto Single Flange / Ka-Band LNBs: Inverto Twin WHITE Ka Circular Dual Polarity LNB (flange), Inverto IDLK-SINL20-KAKU-OPP,MCL-KP04, Norsat 9000HX-O3B-BN, Orbital LNB1825F-1000D-WF55
    Feeds: Invacom ADF_10 + 2 rings, XMW Ka-band Feed FD9000K / Waveguide Polariser: AV-COMM / Tuner: TBS 6925, TBS 6903, TBS 6903X, TBS 6522
    satesco,
    Your report is about 10754 V - I put it in the list. :3:
  • Galaxy25 official range 11.7-12.2 GHz (won't it be Amos 4?)
    Ah, now I can see, thanks EnoSat!
    11056 V 10000 already reported in 65.0°E toppic and updated in GS list. Checked this signal myself now.
    PS: Galaxy 25 is at scan time +2.15° inclinated. It was my fault and I corrected the GS list now. Thanks to satesco and EnoSat!
